Icon helmet: tooke visor off, doesn't fit correctly now.
Hey guys,
Well I popped the visor off for the first time on my Icon Alliance helmet in order to clean it a little bit. It took me forever to figure out how to put it back on and now one side does not fit snug at all. Its to the point where if I was to open the visor 100% open it would fall off. Anyone else have problems like this? Am I going to have to buy another visor or helmet? The problem seems to be with the fitment of the tiny piece that goes between the visor and the helmet itself..its not fitting tight like it should.
I have an Icon Helmet in addition to others and I find their visor changing is one of the easiest around. there should be two clips you slide to unlock it to take it off and then when you put it back on, you move those clips back over to snug down the visor. Obviously you have to do this with the visor up at all times. It should just pop right in with minimal effort and then secure it with the sliding clips.
Hm..maybe its my model but there are no parts that simply slide. I had to physically like pop them off and the pieces between the visor itself and the helmet rotate on the visor but when turned to a certain point, unlock and pop off.
