ATF in a 4sp MT?
Old Oct 11, 2006 | 10:22 AM
Discontained's Avatar
Default ATF in a 4sp MT?
I have heard from reliable sources that i can use ATF (automatic tranny fluid) in my manual tranny. Normally i wouldnt bother asking this but since i have enough laying around, and i have no gear/motor oil laying around. Could i use this for say a couple hundred miles? I dont see it hurting anything. It will be changed out say next paycheck. Yes ill get MTF from honda. Thanks in advance
Old Oct 11, 2006 | 10:25 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: ATF in a 4sp MT? (Discontained)
I wouldn't try it use it as motor cleaner
Just run gm snyrcomesh, or heck those trannys run off normal motor oil, to me it's stunning.
Old Oct 11, 2006 | 10:29 AM
A motor cleaner? Well the only reason is i just changed my cv axles and i dont have any new oil, so i am NOT putting this old oil back in, I was just gonna use it to go to work and to the auto store today andmaybe tomorrow, friday ill change it. Would this be alright?
Old Oct 11, 2006 | 10:44 AM
Ass$nyper's Avatar
Default Re: (Discontained)
I am not 110% sure what ATF is made up of, but I know it holds alot of deturgeants and the such, hence propprly used it can clean a motor like seafoam,i've used this trick on my old truck and few other cars/trucks.
I'm not quite sure what kind of oils and what viscostiy they have in the tranny..
Me i'd honestly not gamble unless your old oil is mad foul if its just to friday reuse it.
Maybe some one who knows exactly what ATF is made of can shed more light.
Old Oct 11, 2006 | 11:47 AM
redzcstandardhatch's Avatar
something different
Default Re: (Capt. Blonde Beard)
just go buy some cheap 10w30...or honda MTF.
just a few bucks, like 3.50, for 2 QUARTS
Old Oct 11, 2006 | 12:00 PM
Default Re: (redzcstandardhatch)
i understand that, i was asking if i could use it. Not what all i could use. I am seeking input on USING ATF. Thanks tho
Old Oct 11, 2006 | 12:11 PM
Boosted Chemist's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Discontained &raquo;</TD></TR><TR><TD CLASS="quote">i understand that, i was asking if i could use it. Not what all i could use. I am seeking input on USING ATF. Thanks tho</TD></TR></TABLE>
i wouldnt use atf. Its not worth risking your tranny for a saving of 4 bucks in 10w30.
Old Oct 11, 2006 | 03:02 PM
EF001282's Avatar
Default Re: (Boosted Chemist)
I use to work at jiffy lube and one of the guys that work with me, put dex3 (another type of auto trans fluid) in an HF trans by shear stupidity and it was'nt driving or shifting properly. when we switched back to reg 10w30 it got a little better but still wasnt quite right, we ended up flushing it 6 more times and also added 4 oil cleaners until he said it was how the customer remembered before the atf mishap. I wouldnt do it but its your trans.
Old Oct 11, 2006 | 04:19 PM
Lol, alright, i was just wondering, looks like i have some 10-40 sitting in the garage..
Old Oct 11, 2006 | 04:48 PM
C_R_X_V_T_E_C's Avatar
the dexron in the ATF messes with honda manual trannys, because honda trannys are real picky about the fluid you use in them.
my 0.02 dont.
yeegsr
24
Dec 25, 2004 08:24 PM
paybac4223
Mar 12, 2003 04:41 PM
wizzards581
12
Mar 6, 2003 11:15 AM
Mikey
Oct 5, 2002 04:14 PM
Ri5e
Mar 16, 2002 07:17 AM
