Suspension & Brakes Theory, alignment, spring rates....
Two questions
Old Oct 11, 2006 | 09:32 AM
DFW's Avatar
DFW
Default Two questions
First, is it ok to have the collar this close to shock "cup"? It's really close to touching it but it's not. Does the collar move around and would it be a problem having it that close to it?
Second, just installed brand new GC's on with custom spring rates on AGX's and there has been strange noises while driving. Took a look today and it looks like the springs have been rubbing against the sleeve. I could see and feel metal on the other side of the springs.
Old Oct 11, 2006 | 02:18 PM
nonsense's Avatar
Default Re: Two questions (DFW)
what length spring is that? I'd think that a shorter spring would solve both issues.
Old Oct 15, 2006 | 10:50 PM
DFW's Avatar
DFW
Default Re: Two questions (nonsense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense &raquo;</TD></TR><TR><TD CLASS="quote">what length spring is that? I'd think that a shorter spring would solve both issues. </TD></TR></TABLE>
Maybe I don't understand, but how would that answer both question?
But anyways I guess it is fine for the first question becuase I've been driving around since then and don't have any problems...
Old Oct 16, 2006 | 12:16 AM
chrisw85's Avatar
shorter springs would mean the perch would have to be higher to make up the difference in heigth and length.
Old Oct 16, 2006 | 08:24 AM
DFW's Avatar
DFW
Default Re: (chrisw85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 &raquo;</TD></TR><TR><TD CLASS="quote">shorter springs would mean the perch would have to be higher to make up the difference in heigth and length.</TD></TR></TABLE>
Well yeah I understand that, how would that solve the noises as I stated in the second question.
Old Oct 16, 2006 | 10:12 AM
nonsense's Avatar
Default Re: (DFW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW &raquo;</TD></TR><TR><TD CLASS="quote">
Well yeah I understand that, how would that solve the noises as I stated in the second question.</TD></TR></TABLE>
The shorter spring wouldn't buckle as much and won't hit the threaded sleeve.
Old Oct 16, 2006 | 12:38 PM
FalkenSiR's Avatar
Default Re: (DFW)
My GC sleeves (used) came with some thick rubber rings (3 per corner) that I placed inside the sleeve against the shock body. What they do is exactly to avoid the problem you're having.
Old Oct 16, 2006 | 12:40 PM
DFW's Avatar
DFW
Default Re: (fast95eg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast95eg8 &raquo;</TD></TR><TR><TD CLASS="quote">My GC sleeves (used) came with some thick rubber rings (3 per corner) that I placed inside the sleeve against the shock body. What they do is exactly to avoid the problem you're having.</TD></TR></TABLE>
Were they small black rings?
Old Oct 16, 2006 | 03:21 PM
lowinc's Avatar
They should not be that close, you should shave the cup on the strut or raise it back up if not you will damage your gc, and for the rubbing is that the sleeve is not installed correctly make sure you install those black rubber rings and make the sleeve tite and even. good luck
Old Oct 18, 2006 | 06:58 AM
porter's Avatar
I'm a Jackass
Default Re: Two questions (lowinc)
im having the same problems
Old Oct 22, 2006 | 02:20 PM
porter's Avatar
I'm a Jackass
Default Re: Two questions (tilf)
AamirCWITR
Suspension & Brakes
May 8, 2007 11:59 AM
The Jacko
Suspension & Brakes
Jan 31, 2006 01:44 PM
bosco500
Jun 8, 2005 05:32 AM
bosco500
Suspension & Brakes
Jun 7, 2005 08:28 AM
Dan
Apr 25, 2003 06:58 AM
