Tips on bleeding brakes on a 91 Si Hatch?
Old May 3, 2002 | 06:34 AM
Todd00's Avatar
I said I don't want a title!
Default Tips on bleeding brakes on a 91 Si Hatch?
Probably going to bleed my brakes tonight to try and get back some pedal firmness. Any tips or anything unusual to look out for on the EF's?
Also, which wheel do you start with and then what order afterwards?
Old May 3, 2002 | 06:48 AM
Superhatch's Avatar
Default Re: Tips on bleeding brakes on a 91 Si Hatch? (Todd00)
tip #1 : use 2 people.
tip #2 : get a manual of some sort.
Thats about it. (I was the pedal pusher when we did mine...so I cant really tell you beyond that, but I know those two tips will help you out a ton
-Jake
Old May 3, 2002 | 06:55 AM
keithv's Avatar
Default Re: Tips on bleeding brakes on a 91 Si Hatch? (SuperHatch)
i've heard a few different things on the brake bleeding order. i always start from the furtherest caliper away from the reservoir and work my way closer. i've also heard that hondas have a system and you should do it differently than that...
but i go... pass. rear, driver's rear, pass. front, driver's front. that seems to work for me...
Old May 4, 2002 | 08:09 AM
Mista Bone's Avatar
D Tranny Guru
2 tips.......
speed bleeders
RR-LF-LR-RF
Old May 4, 2002 | 09:00 AM
fixhondas's Avatar
On such an old car, it may not be a good idea to go pushing the pedal all the way down while bleeding, there is alot of residue (gunk) that is in your MC that the piston seals don't ever reach- when you push the pedal down fully (w/ open bleeder) you will drag the seals over this gunk and likely cause your seals to fail rather quickly. Many times new fluid in an old,neglected brake system can cause MC failure. You can bleed by just cracking open the bleeder and letting it gravity bleed- sometimes a slight push on the pedal is necessary to clear rust that builds up in the bleeder screw to get things flowing.
Old May 5, 2002 | 07:40 PM
Todd00's Avatar
Default Re: Tips on bleeding brakes on a 91 Si Hatch? (fixhondas)
Never thought of that. Maybe that's the reason a friend of mine had to replace his MC after he bled everything.
96hb
Suspension & Brakes
Oct 28, 2010 08:52 AM
Mavrick
Oct 17, 2006 12:51 PM
BDietrich84
May 8, 2005 05:50 PM
SOHC Gord
26
Jan 4, 2005 03:17 PM
DieMaster
18
Nov 9, 2004 07:41 AM
