installation of lip
Old Oct 11, 2006 | 05:53 AM
EKshin's Avatar
Default installation of lip
I have a CTR style front lip. Anyone have instructions on how install it?
Old Oct 11, 2006 | 05:55 AM
0334973's Avatar
they way i installed mine was i put two screws on the underside and one at each end of the lip. worked out pretty well.
Old Oct 11, 2006 | 05:59 AM
sicones's Avatar
Default Re: (0334973)
get some screws and a screwdriver...please don't use drywall screws
Old Oct 11, 2006 | 06:03 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">...please don't use drywall screws</TD></TR></TABLE>
lol thats what I did . I'm lazy/cheap
Old Oct 15, 2006 | 04:53 AM
white ej2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0334973 &raquo;</TD></TR><TR><TD CLASS="quote">they way i installed mine was i put two screws on the underside and one at each end of the lip. worked out pretty well.</TD></TR></TABLE>
did u use just regular screws??.. would some small nuts and bolts be better or no
Old Oct 15, 2006 | 05:53 AM
jdmOPTION2's Avatar
yes it would be much better...!!!
just pre drill the hole to the size of the bolt and use little washers, then paint to match it up
Old Oct 15, 2006 | 10:25 PM
broketuner-Sol_Si's Avatar
Default Re: (jdmOPTION2)
or you could just rivet it on, but small bolts with nyloc nuts would work best.
Old Oct 15, 2006 | 10:34 PM
lowsiciv's Avatar
Default Re: installation of lip (EKshin)
a couple screws and some high performance double sidied tape works awesome. we did that on my buddys spoon lip.
Old Oct 15, 2006 | 10:48 PM
imaginAZN's Avatar
64.175.64.11
Default Re: (white ej2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white ej2 &raquo;</TD></TR><TR><TD CLASS="quote">
did u use just regular screws??.. would some small nuts and bolts be better or no</TD></TR></TABLE>
lmao he said small nuts
Old Oct 16, 2006 | 12:36 AM
bhsftball55's Avatar
self tapping screws are the best....can be bought anywhere. wal-mart... home depot..freddys.. they look like a normal screw but has a drill bit type tip. that way, it screws in nicely. holds on verry good. but yeahh,,,, cant beat small nuts and washers
Old Oct 16, 2006 | 05:07 AM
1slow4dr's Avatar
i put 2 screws on each side of the front bumper where the splash guard is.
Old Oct 16, 2006 | 06:10 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: installation of lip (1slow4dr)
DO you actually have to drill into the bumper when installing the lip? I thought on 99-00 there was factory mounts for it. I could def. be wrong.
Old Oct 16, 2006 | 09:40 PM
Ek Forever y0!
Default Re: installation of lip (ek forever guy)
Denied....
Old Oct 16, 2006 | 09:59 PM
Tuesdaynightfever's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">DO you actually have to drill into the bumper when installing the lip? I thought on 99-00 there was factory mounts for it. I could def. be wrong.</TD></TR></TABLE>
The bumpers have rivets of where to drill the holes.
Old Oct 16, 2006 | 10:00 PM
Eran's Avatar
HT White Ops
The bumpers do have factory mounting locations and factory hardware .... but that only applies if you have a REAL CTR lip.
Old Oct 16, 2006 | 10:26 PM
bmoua's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">The bumpers do have factory mounting locations and factory hardware .... but that only applies if you have a REAL CTR lip.</TD></TR></TABLE>
yep unless its a oem ctr or EM1 lip then they wont come with the factory mounting locations...
Old Oct 18, 2006 | 10:26 AM
Ek Forever y0!
Default Re: (bmoua)
So you have to drill the lip into your bumper wherever you see fit?
Old Oct 18, 2006 | 10:35 AM
Eran's Avatar
HT White Ops
Default Re: (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">So you have to drill the lip into your bumper wherever you see fit?</TD></TR></TABLE>
Best way to do a CTR-style lip for a 96-98:
Is to put two self-tapping screws on the part that folds into the wheel wel, and use 3m double-stick waterproof tape on the part that sits in the mouth of the bumper.
Old Oct 18, 2006 | 10:41 AM
Archidictus's Avatar
Unceasing Measure
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">Best way to do a CTR-style lip for a 96-98:
Is to put two self-tapping screws on the part that folds into the wheel wel, and use 3m double-stick waterproof tape on the part that sits in the mouth of the bumper.</TD></TR></TABLE>
Quoted for truth.
Old Oct 18, 2006 | 10:49 AM
Eran's Avatar
HT White Ops
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Quoted for truth.</TD></TR></TABLE>
As soon as I get my SiR knock-off lip, I'm also gonna do a write-up on how to have an SiR style lip with hardware, installed for less than $200.
Fark the original part cost:
JDM Lip - $170
Honda OEM Hardware - $50
Shipping $100
Cost $320
Old Oct 18, 2006 | 04:32 PM
Ek Forever y0!
Default Re: (Eran)
Doens't jdmshit's lips come with hardware? Prices are shipped as well. I was thinking about getting the CTR lip from them.
Old Oct 18, 2006 | 04:36 PM
knockout's Avatar
Default Re: (Eran)
JDM Lip - $170
Shipping $100
Cost $320 </TD></TR></TABLE>
for me, it was under $110
Polyurethane SiR knockoff lip - $100
6 self tapping screws (black) from Home Depot - $3
Roll of thin double sided adhesive waterproof tape - $4
Old Oct 18, 2006 | 04:37 PM
Ek Forever y0!
Default Re: (knockout)
^ Word.
Old Oct 18, 2006 | 05:32 PM
Midori Green's Avatar
Does anybody know where i can find an SiR front bumper lip for my 96 hatch. I only have about $100-$120 can i work with that? If i can where can i get this lip because it seems to be pretty rare! Somebody please help me!!!!
Old Oct 18, 2006 | 05:46 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knockout &raquo;</TD></TR><TR><TD CLASS="quote">
Roll of thin double sided adhesive waterproof tape - $4</TD></TR></TABLE>
****, I haven't EVER seen the lip for less than $160 shiiped. I just bought mine today. And I'm not using double sided. I'm using actual spring clips and bolts. So it'll still utilize factory mounting points.
