ok now it really wont start.
Old Oct 10, 2006 | 10:10 PM
2poor2tune's Avatar
Default ok now it really wont start.
ok so i checked all that ground for my car and they are good. checked the starter signal fuse and the car wont crank at all anymore. i also had the starter tested at autozone. it came out good. so now i need to really get into the details of the starter wiring i think. first does anyone know what the little wire does that goes to it. i do have it hooked up but im guessing that is what gives the starter a signal for go time. and then it kicks right. i also think it is just a ground wire. if any one can tell me that would be great thanks.
Old Oct 10, 2006 | 10:15 PM
ic's Avatar
ic
Default Re: ok now it really wont start. (2poor2tune)
Old Oct 10, 2006 | 10:22 PM
2poor2tune's Avatar
WTF you dietn even pst anything. you got my hopes up. damn help me somone. thanks
Old Oct 10, 2006 | 10:46 PM
crxnj's Avatar
you sure the thermostat ground is hooked up?
Old Oct 10, 2006 | 10:54 PM
2poor2tune's Avatar
yes sir. both of them are. i have 2 ground washer things tho put a bolt threw and did it. buy do you know if the little wire is a ground?
Old Oct 10, 2006 | 11:12 PM
2poor2tune's Avatar
Default Re: (2poor2tune)
ok im going to give the little wire prong thingy a sourse of ground and see if it is infact a ground thingy. i will let you know. i hope my car doesent blow up or fry any wiring. oh well here i go.
Old Oct 10, 2006 | 11:27 PM
2poor2tune's Avatar
well i tried grounding the wire and gave power to the wire. and the wire needs power to turn over and it scared the crap out of me sitting all alone in the middle of the street when it sparked.
Old Oct 10, 2006 | 11:47 PM
2poor2tune's Avatar
ok so since im pretty much alone in this thread. i will let everyone who cares know how i got my car to start. i just simply grabed a switch i had lying around and put a wire from the starter signal input signal to the switch and a 12v source on the other side of the switch and turned my car to on position and fliped my fuel pump switch and fliped my starter switch i just made. it all worked out great and i guess i will just run the switch to under my seat untill i figure out what the reall problem is. hahaha or i will just install a s2k strater button
Old Oct 11, 2006 | 12:14 AM
Chiovnidca's Avatar
Have you checked the ignition switch?
Old Oct 11, 2006 | 04:49 AM
89 civic si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2poor2tune &raquo;</TD></TR><TR><TD CLASS="quote">ok so since im pretty much alone in this thread. i will let everyone who cares know how i got my car to start. i just simply grabed a switch i had lying around and put a wire from the starter signal input signal to the switch and a 12v source on the other side of the switch and turned my car to on position and fliped my fuel pump switch and fliped my starter switch i just made. it all worked out great and i guess i will just run the switch to under my seat untill i figure out what the reall problem is. hahaha or i will just install a s2k strater button</TD></TR></TABLE>
at least you got it started but doesnt that mean you found you problem also lol i agree with 2poor2tune from everything you said your ignition switch is bad
Old Oct 11, 2006 | 05:04 AM
Default Re: (89 civic si)
OOPS 2poor2tune was the creator of the post anyways check that ignition switch
Old Oct 11, 2006 | 02:39 PM
2poor2tune's Avatar
yeah thanks for the ifo. im gonna check that and if ti dont work im gonna just buy a s2k button or have a secret stock button to start it up.
Daved144
Aug 11, 2011 03:24 PM
JDM C.A.R
May 9, 2010 04:38 PM
LsScivic
Mar 4, 2009 07:39 PM
E36 Guy
11
Jan 19, 2005 07:18 AM
Leets
13
Mar 13, 2002 06:09 AM
