To thouse with Spoon fly....
Have any of you gotten grinding while starting your car? It sounds like when you try to start a car when its already running
I know they had issues with the older flywheels, but I thought that problem was with the pinion gear hitting the ring gear. Anybody else have this problem? Will chaning over to the JDM starter/pinion assembly help?
Craig - Who hopes he does not have to drop the tranny again for a while
I know they had issues with the older flywheels, but I thought that problem was with the pinion gear hitting the ring gear. Anybody else have this problem? Will chaning over to the JDM starter/pinion assembly help?Craig - Who hopes he does not have to drop the tranny again for a while
Hopefully that will be the case.
Craig - Who has had it on for 5 days and it made the noise twice so far
[Modified by AssPenny, 9:49 AM 5/3/2002]
My sp00n hasn't done it yet on about 10 starts. Maybe it's because FL = burnt to the ground?
coin you got the Al or chromoly?
does spoon even make an Aluminum?
[Modified by sackdz, 9:52 AM 5/3/2002]
:middlefinger:
So are there realy different spoon flywheels? I know there was an old design and new design with the ring gear, but I thought the material was the same on all of them.
yes...its the starter teeth grinding with the teeth on flywheel.... i spoke to ragingangel who had this flywheel in his car for a while, and he said it would dent the flywheel teeth until he switched over to a civic SI/SIR starter, and that solved the problem...
beware!
beware!
Craig,
It is the teeth of the starter not meshing with the teeth on the FW. The Toda is angle ground to easily accept the different starters used by Honda. Problem is def starter dependant. Let me know if you want to switch out to the Toda...
By now, your tranny probably comes off by itself, right?
Hahaha.. no ****... We can drop a tranny in about 30 minutes now... and that includes a beer break
As for the toda, I think I'll just swap the starter for now... lot easier then a tranny drop, plus i'm sick of droping trannies (5 times in the past 2-3 months
Craig - Who is getting sick of working on cars and just wants to drive....
[Modified by AssPenny, 10:51 AM 5/3/2002]
)Craig - Who is getting sick of working on cars and just wants to drive....
Come on... one of you fawking junk yard ****** have got to be able to find me one at a good price...
Craig - who does not have a junk yard with in 50 miles of him
I had this stupid *** problem with mine and I got pissed off enough to rape the starter off my friend's SiR/Si and there is definately a difference when you take them out and compare them hand in hand.....side by side....
the Mitsuba (SiR) starter seems to be weaker so the car sounds labored when it is turning over.....but it's no problem at all...
Been using it for quite a while now.
00-0187: If I am able to trade starters with you.... well check your IM please.....
For all those with the Denso starter and have no grinding problems.......CURSE YOU ALL TO HELL.....
hehehe
hehehe
