accord h22 problems
Old Oct 10, 2006 | 08:37 PM
DAGAME's Avatar
Default accord h22 problems
ok i have a 1996 honda accord with 1998 jdm H22A with 1999 OBD2 H22a ECU, and i am getting 4 to 5 engine light codes and now when i go past 6,000 RPMs my car starts backfiring and doesnt want to rev any higher, has anyone had this kind of problem with the h22a in a accord. Here are the CEL codes :
P1491 Fuel Air Metering
P0138 O2 sensor high voltage
P1457 Fuel Air Metering Aux emission controls
P0136 O2 sensor circuit malfunction
P1491 Manufacturer Control Aux emissions controls
Old Oct 11, 2006 | 07:39 PM
DAGAME's Avatar
alright changed the secondary o2 sensor, but still backfires after vtec engagement and hesitates, going to try changing the plugs and wires and see it that solves the problem. Does anyone have an idea of what the problem could be?
Old Oct 13, 2006 | 05:17 PM
DAGAME's Avatar
alright changed the plugs and wires and external msd coil wire and still no luck still backfiring after vtec engagement, anybody have any ideas?
Old Oct 13, 2006 | 07:58 PM
rollercosta123's Avatar
Default Re: (DAGAME)
ch
Old Oct 14, 2006 | 12:59 AM
NOFX's Avatar
H-T White Ops
Are you running a P5P or a P13 as you said in another thread? You mentioned running a "stock obd2 p13 prelude ecu" in the other thread... the P13 is an OBD1 ECU.
Oh, and also, you said you changed the secondary O2, so I'll assume (I know... shouldn't do that... especially with Honda O2 sensors) that perhaps your'e no longer throwing that code (P0138 Secondary Heated Oxygen Sensor Circuit High Voltage).
Here are the "interpretted" codes you're probbaly currently throwing now then.
P1491 Exhaust Gas Recirculation (EGR) Valve Insufficient Lift
P1457 Evaporative Emissions (EVAP) Control System Leakage (EVAP Canister System)
Modified by NOFX at 5:28 AM 10/14/2006
Old Oct 14, 2006 | 01:35 AM
NOFX's Avatar
H-T White Ops
Oh, and check to make sure your EVAP and EGR tubes aren't in plugged in wrong.
https://honda-tech.com/zerothread?id=748876
Modified by NOFX at 2:11 PM 10/14/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">P1491 = EGR valve insufficient lift.
The exhaust-gas recirculation passageways in the intake manifold can get clogged. I suppose that's true for V6 also? ....
P1457 = EVAP system leak, control canister system.
There's a half-dozen valves, bunch of vacuum tubing, a filter, & a charcoal canister under the back seat. Something's not airtight... The canister vent-shut valve is a common failure (mine did) but this is another case where there's several pages of checks in the Helm manual to find which part is actually bad.</TD></TR></TABLE>
Modified by NOFX at 2:14 PM 10/14/2006
Modified by NOFX at 2:15 PM 10/14/2006
Old Oct 16, 2006 | 06:40 AM
DAGAME's Avatar
ok finally fixed the problem, the msd box and msd external coil were bad, replaced the coil and bypassed the msd box and everything runs pretty damn good now, i am still getting an O2 code though for high voltage and those 2 codes above that might be because im running a 99 ecu on a 98 motor. Im sure those will go away once i get chipped P28 and get it tuned : )
Old Oct 19, 2006 | 09:26 PM
cd555's Avatar
Default Re: (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">Are you running a P5P or a P13 as you said in another thread? You mentioned running a "stock obd2 p13 prelude ecu" in the other thread... the P13 is an OBD1 ECU.
[/i]</TD></TR></TABLE>
Not all P13 ecu's are obd1, a P13-A12 is obd2 out of the 96 prelude vtec
Old Oct 20, 2006 | 10:47 PM
NOFX's Avatar
H-T White Ops
Default Re: (farroutt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by farroutt &raquo;</TD></TR><TR><TD CLASS="quote">Not all P13 ecu's are obd1, a P13-A12 is obd2 out of the 96 prelude vtec</TD></TR></TABLE>
Interesting. I did a search and didn't find any info on that ECU. I'll have to add that to my list then. Thanks. Sorry for the screw up.
jdm_krish
Apr 17, 2025 07:16 PM
Stephenrod
Aug 18, 2010 01:58 PM
702accord
Nov 18, 2009 08:05 PM
gibbythered
Jan 16, 2008 04:05 AM
JDMHatch101
Mar 28, 2005 09:39 AM
