HELP!!! Brake again
Old Oct 10, 2006 | 06:24 PM
Seatown's Avatar
Default HELP!!! Brake again
I wish somebody would have told me how difficult it is to remove brakes lines from the master cylinder. Took me an hour and a half just to remove one 10mm with a flare wrench.
Anyway was getting ready to bench bleed my MC minus the bench. I have a solo bleeder kit. My PROBLEM, one of the screw that comes with the new master cylinder felll under the hood somewhere, its dark now and I cant see anything. This makes the bleeder kit pointless.
I'm going to have to block one hole with my hand and attach the rest of the kit. My question is how do I know air is not entering from the side my hand is covering?
Old Oct 10, 2006 | 07:24 PM
Seatown's Avatar
Default Re: HELP!!! Brake again (Seatown)
Old Oct 10, 2006 | 08:49 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Seatown &raquo;</TD></TR><TR><TD CLASS="quote">I wish somebody would have told me how difficult it is to remove brakes lines from the master cylinder. Took me an hour and a half just to remove one 10mm with a flare wrench.</TD></TR></TABLE>
It took me 1 minute to remove both of them. You must have no arms and use your teeth to turn the wrench or something . . .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Anyway was getting ready to bench bleed my MC minus the bench. I have a solo bleeder kit. My PROBLEM, one of the screw that comes with the new master cylinder felll under the hood somewhere, its dark now and I cant see anything. This makes the bleeder kit pointless.</TD></TR></TABLE>
Flashlight? Droplight? Magnet?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I'm going to have to block one hole with my hand and attach the rest of the kit. My question is how do I know air is not entering from the side my hand is covering?</TD></TR></TABLE>
Don't worry about it too much. Bench bleeding isn't 100% required - it only saves time and brake fluid. If you don't bench bleed the MC, you'll just spend more time bleeding the system out. In the hour you waited to bump this thread, you could have been finished.
2theekidd3
May 10, 2013 04:01 PM
callmetree19
Nov 16, 2008 02:47 AM
mixmastabob
Dec 7, 2006 12:09 PM
dip-set
Feb 5, 2004 01:08 PM
magbarn
May 22, 2003 03:28 PM
