rubbing???
Old May 3, 2002 | 04:06 AM
Lo-Buck EF's Avatar
Default rubbing???
anyone have problems with rubbing on STOCK suspension? stock ef hatch springs, shocks (not blown as far as i know) and shitty 175 m+s. there not overly tall (lke 60 or 70 series sidewall.) i know the right side rubs a bit when i have my race tires on and th autocross lot is bumpy(205 kumho victoracers) but lastnight the left side rubbed on aright hander with a bump on entry.
Old May 3, 2002 | 05:24 AM
keithv's Avatar
Default Re: rubbing??? (SOLOef)
i didn't rub with my 175 m+s and i'm lowered like 2"...
but maybe since your on the stock suspension you have a bit more sway and you rubbed b/c the tires are not in the temp ranage they are spec'd for? i know my snows get squirrely in the warmer weather...
Old May 3, 2002 | 09:01 AM
Lo-Buck EF's Avatar
Default Re: rubbing??? (breaka_1_9)
possibly. as long as it doesn't f*$K up the tire, i'm not too worried about it. when i lower it, i may have a problem but i'll deal with it then. its not gonna be for a while anyway since i'll have to get it set up for fsp.
Old May 5, 2002 | 08:52 PM
EF_LSVtec's Avatar
What kind rims are you using? Check the offset...
Old Jun 4, 2003 | 05:19 AM
Lo-Buck EF's Avatar
Default Re: rubbing??? (EF_LSVtec)
holy old thread. yea, that was the mudflap rubbing the ground...
oskar_0709
Suspension & Brakes
10
Oct 19, 2010 07:49 PM
civic_66
Apr 17, 2007 06:09 AM
DannyITR
May 5, 2006 10:04 PM
D-Atk
13
Aug 6, 2005 10:07 PM
avs
Jun 11, 2003 09:19 PM
