Need some serious alarm help. HELP HELP HELP SOS SOS SOS
I bought my Lude about 5 months ago and it has a Clifford alarm on it, I have looked for a valet switch before but did not see one. Well today I busted my only alarm pad at work and my car is in my garage with the wheels off, doors locked, and alarm set.
My question is, how can I turn the alarm off after I use my spare key to get in the car? I need help pretty quck as I have to drive it to work tomorrow.
If nothing else I guess I can start ripping the alarm apart, I hate to do this because it is a good alarm but I might have no choice.
BTW I have no idea what model it is.
Well, you're going to need to get a model number before we can give you real help.
If you can get to the brain, DEI units usually have a blue plug for the valet switch. You could look for the blue plug and follow that wire back to the valet switch. If the installer didn't put it in, you're kindof screwed.
Your other alternative is to pull the main power fuse or the main wiring harness from the unit until you can figure it out...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 »</TD></TR><TR><TD CLASS="quote">Well, you're going to need to get a model number before we can give you real help.
Your other alternative is to pull the main power fuse or the main wiring harness from the unit until you can figure it out...</TD></TR></TABLE>
If I unhook the batt and find the switch would I be able to deactivate the alarm with it when I hook the batt back up?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 »</TD></TR><TR><TD CLASS="quote">Provided there is a switch, yes.</TD></TR></TABLE>
Pm Sent
My box has the 2 prong blue spot for a switch but there is not one, but I have another no name alarm in a box with a switch that says on/off that has the same style plug that is blue can I plug this one and use it?
Pm Sent
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
no, Your best bet is to run to a local stereo shop and see if the have a spare dei valet switch just laying around. Should cost no more then 1 to 3 buxs. plug it in they shut off the alarm. Hey if you found the brain what the model number.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater »</TD></TR><TR><TD CLASS="quote">no, Your best bet is to run to a local stereo shop and see if the have a spare dei valet switch just laying around. Should cost no more then 1 to 3 buxs. plug it in they shut off the alarm. Hey if you found the brain what the model number.</TD></TR></TABLE>
Model from what i can see M202905 04
The thing is I have to drive to work in the morning.
when trying to use the switch do I need to turn the key to on then do the switch? since this switch is on/off would I need to leave it in the on or off postion?
THE GUY
Audio / Security / Video
12
Aug 20, 2009 12:21 PM
Project.Jdm
May 22, 2008 04:19 PM
