Noise From Front Driver side wheel
Old Oct 10, 2006 | 02:58 PM
jojo69's Avatar
Default Noise From Front Driver side wheel
Hi all and thank you in advance,
93, Accord EX, Auto, 161K,
After a trip to the Dealer, I noticed a noise that is coming from the front Driver side tire.
Every time I go over a bump, I hear like steel on steel noise.
All ball joints look ok to me after checking them.
Any idea what could it be?
Thanks,
Joey
Old Oct 10, 2006 | 03:24 PM
Dinzdale40's Avatar
how old are your brake pads....if they are old it could be the wear indicators....if not they may just have something in between the pad/rotor...
Old Oct 11, 2006 | 04:09 AM
jojo69's Avatar
Default Re: (Dinzdale40)
Brakes are new. About 6 months old.
The noise is coming from somewhere under the hood right above the spring/shock absorber.
I checked the spring, it is not broken.
Any idea?
does this car has any bushing in that area that goes bad?
Thanks,
Joey
Old Oct 12, 2006 | 10:52 PM
Cronousman's Avatar
Default Re: Noise From Front Driver side wheel (jojo69)
describe the noise more in depth
Old Oct 13, 2006 | 07:06 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jojo69 &raquo;</TD></TR><TR><TD CLASS="quote">
A clank noise? Have you checked the swaybar end link bushings?
Old Oct 14, 2006 | 12:19 PM
Chanclr's Avatar
i am having a lot of noise on my driver's side too and it's not sounding great. upper control arm has to go on my 96 ex. i am not sure what noise you're having but i hope you get the problem identified and resolved. good luck.
Old Oct 14, 2006 | 03:44 PM
TOAB's Avatar
So it's only when you go over bumps? Like control arm coming up too high and making contact with the car? Aside from metal on metal... what exactly does it sound/feel like?
Old Oct 21, 2006 | 03:23 PM
jojo69's Avatar
Default Re: (TOAB)
It happens everytime i go over a bump.
Again, it is like a knocking steel to steel noise.
it is coming from the Struts area, right under the hood.
Is there a way to check my upper control arm?
Thank you all again.
Joey M.
Old Oct 26, 2006 | 10:09 PM
PnX-R's Avatar
Default Re: (jojo69)
To check the upper control arm and ball joint??... Just jack up the front end of the car so that the front wheels are off the ground. Take your hand and try to move the tire in and out, if it's your upper ball joint/control arm, you'll definitely know for sure..
Old Oct 27, 2006 | 04:28 AM
mkvleli's Avatar
Hey I had the same problem with my 97 accord
The shop said that it was a piece of rusted steel that covers the treansmision
I think they were right because they fixed it and no more sound.
I also had the same sound when i was in 3rd or 5th gear at about 4 rpm.
Hope I was a little help.
Honda Accords RULE!!!!!
Old Oct 27, 2006 | 02:14 PM
jojo69's Avatar
Default Re: (PnX-R)
that is exactly what i did. but no result.
the car has low suspension. I was wondering if they come with some kind of pads and the pad got worn out.
The noise sounds like it is coming from the top of the strut. The area where it is mounted under the hood to the fender.
Any suggestions.
Thank you all
Joey
Dackonn
Suspension & Brakes
37
Mar 2, 2025 02:16 PM
mrongey
Feb 26, 2013 06:44 AM
kcari
Suspension & Brakes
Jul 15, 2010 04:01 PM
jasony0630
May 27, 2008 11:13 AM
erikiksaz1
Sep 13, 2004 06:00 PM
