lude does't want to shift, help plz
Old Oct 10, 2006 | 02:09 PM
Ri'can Luder's Avatar
Default lude does't want to shift, help plz
here's the story, i was out buying some food, went through the drive through when i went onto the road i was shifting it to 1 gear when i went to 2 gear it got hard as hell. it didnt want to shift into any gears. i was just wondering if anyone can help me out. i asked my girlfriends dad and he said i needed a new clutch. can anyone help me out?
Old Oct 10, 2006 | 02:12 PM
prelude1897's Avatar
Default Re: lude does't want to shift, help plz (Ri'can Luder)
if you have a 5spd, check your clutch fluid and be sure it's filled up
Old Oct 10, 2006 | 02:17 PM
Default Re: lude does't want to shift, help plz (prelude1897)
i told my dad about it and he checked the clutch fluid, but when i put the clutch in it kinda shakes and its hard, and in some cases i leave in the clutch and all of a sudden it lets go and i can shift. sometimes i cant even take out one of the gears.
thx for all the help b4 hand
Modified by Ri'can Luder at 3:32 PM 10/10/2006
Old Oct 10, 2006 | 06:40 PM
BUMP
plz i need the help, my car is a daily driver and its a pain in the *** to drive like this.
Old Oct 10, 2006 | 06:42 PM
97BB6Type-SH's Avatar
dont bother checking or changing no fluids or master/slave. its the clutch. i went thru the same thing about a month ago, wishing/hoping it was anything but the clutch but your gonna have to face it, and get a new clutch ASAP.
Old Oct 10, 2006 | 06:44 PM
STOP DRIVING IT! your going to mess up your tranny. im telling u from experience. and its probably a spring that popped out of its retainer. wish u the best of luck.
Old Oct 10, 2006 | 06:56 PM
Default Re: lude does't want to shift, help plz (97BB6Type-SH)
thx for telling me
Old Oct 12, 2006 | 06:41 PM
Here's an update, i took my car to my girlfriends house and told her dad exactly what was wrong with it. He says its the clutch pump, can i get anybody to confirm that or other ideas?
Old Oct 12, 2006 | 06:46 PM
OLDskool91Si's Avatar
clutch pump??...umm clutch master cyl. And i highly doubt thats the problem. It shouldnt get hard to press the pedal. It sounds like the pressure plate to me. Pull the tranny.
Old Oct 13, 2006 | 07:30 AM
Default Re: (OLDskool91Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OLDskool91Si &raquo;</TD></TR><TR><TD CLASS="quote">clutch pump??...umm clutch master cyl. And i highly doubt thats the problem. It shouldnt get hard to press the pedal. It sounds like the pressure plate to me. Pull the tranny.</TD></TR></TABLE>
yeh lol sry i translated it from spanish, but i dont know. hes gonna check the clutch and tell me.
Old Oct 13, 2006 | 07:36 AM
92blkJDMh22's Avatar
if it is a fluid problem... you can normally pump the clutch a few times to build up pressure and shift......
however its sounds like a problem that will require taking the tranny off to figure out.....
good luck...
Old Oct 13, 2006 | 07:47 AM
Default Re: (92blkJDMh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92blkJDMh22 &raquo;</TD></TR><TR><TD CLASS="quote">if it is a fluid problem... you can normally pump the clutch a few times to build up pressure and shift......
good luck...</TD></TR></TABLE>
well my girlfriend just called me and told me that her dad checked the car and that its the clutch master cylinder, its not building up pressure and that i need a new one, can anyone tell me how much that would cost me?
Old Oct 13, 2006 | 07:58 AM
AmauryR's Avatar
Default Re: (Ri'can Luder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ri’can Luder &raquo;</TD></TR><TR><TD CLASS="quote">
well my girlfriend just called me and told me that her dad checked the car and that its the clutch master cylinder, its not building up pressure and that i need a new one, can anyone tell me how much that would cost me?</TD></TR></TABLE>
dude, sounds more like its ur clutch itself. it happened to my friend b4, the car would be impossible to shift, then u shut the car off and start it back up and you can throw the gears a few times (maybe). if its the clutch cylinders you'll see a leak and notice the fluid is low. and even then you'll still be able to shift (after pumping the hell outta it). vibration in the pedal isn't consistent with the cylinders either. but if ya wanna replace the master cylinder + slave cylinder, it'll be less than 200 bucks usually.
Old Oct 13, 2006 | 08:44 AM
Default Re: (Ether Way)
she told me that the master cylinder was dry
so the clutch fluid isnt getting to the cylinder
Old Oct 13, 2006 | 09:14 AM
godslayer's Avatar
Why do people give advice like "I had a friend who had this happen..." and then stand behind their guess like they know what they're talking about?
This isnt the case here but it is very possible to have a blown inner seal on the master cylinder causing blow-by and still have the outer seal/dust seal retain the hydraulic oil.
Old Oct 16, 2006 | 09:39 AM
Default Re: (godslayer)
found the problem, it wasnt the master cylinder, it was the slave, it wasnt sending pressure becuz it was scratching. i guess thats why when i left the clutch in a while it would disengage, becuz the slave clutch was slowly letting go. thx for the help
Old Oct 16, 2006 | 11:36 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ri’can Luder &raquo;</TD></TR><TR><TD CLASS="quote">found the problem, it wasnt the master cylinder, it was the slave, it wasnt sending pressure becuz it was scratching. i guess thats why when i left the clutch in a while it would disengage, becuz the slave clutch was slowly letting go. thx for the help </TD></TR></TABLE>
heres a pic of the old slave cylinder
Old Oct 16, 2006 | 11:41 AM
ninja 6's Avatar
looks like a *****
Maladeen
Nov 10, 2012 07:43 PM
JDMlyfestyle
21
Sep 24, 2004 02:08 PM
PAID-$$$
Jun 11, 2004 12:50 PM
PatrickGSR94
Apr 23, 2003 11:05 AM
Yyz
Oct 23, 2001 07:09 AM
