Honda S2000 Honda S2000
[FAQ/DIY] S2000 NRG X strut brace install
Old Oct 10, 2006 | 01:39 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Default [FAQ/DIY] S2000 NRG X strut brace install
First some notes about this installation. This bar has no flexible joints, and the fitment can be described as EXACT. So what does that mean? If your S2K has been in a frontal accident, you may have some aligment issues with this brace depending on how good your body shop was at aligning the frame back to stock specifications.
Here is what we are putting in:
Disclaimer: This is just a guide to help you install the brace, please dont PM me blaming me for your mishaps if they occur. Some steps were omitted in this write up, and is based on the assumption that you have a decent mechanical sense not to mention a good metric tool set. NRG recommends professional install, but to those of us that are inclined, on to the install
First step, get a buddy to help, trust me, you will need him in the later steps
Here is what we started with, wow what a pretty Cusco bar
Jack up the car, it doesnt have to be too high, and to be safe put stands under there. Next remove the nuts holding the shock tower like so.
Next remove the entire airbox, including the arm
Once the airbox is removed look down and you will see the steering rack. You will notice 2 large bolts holding down the rear side of the rack. Remove those.
Passenger side
Driver's side
Assemble the bar loosely and please note that the X part of the bar is not the same on both sides. The X part is very slightly offset to lean towards the motor. Its not very noticeable to the eye, but once bolted down you will see that it leans towards the motor. If it leans towards the bumper, flip it around.
Now here comes the fun part where you will use your buddy, remember to buy him a beer afterwards. Drop the bar in place for a test fit. Thread in the steering rack bolts that you have previously removed, but do not tighten because you will need lots of play when trying to put the upper part of the bar on.
Now that you have the bottom part loosely on, now its time for the top. Have your buddy go on the other side. You will notice that it seems like both of the shock tower mounts dont want to line up. Push and pull with your buddy to get it as close as possible.
At this point, the ends of the upper bar is a pain in the *** to get over the shock tower bolts right? Here is the trick, which I why I told you to jack up the car a little. Step on the rim like pictured below. This will drop those shock tower bolts down enough for you to line up the ends of the bar.
Now that everything is lined up, bolt everything down.
Put the airbox back on and take a look at the finished product
Here is the finished product on another S2000 that we did
More info on this bar here:
https://honda-tech.com/zerothread?id=1777393
Old Oct 10, 2006 | 01:45 PM
p nut's Avatar
Hey, a little Simple Green's not going to hurt that engine bay.
Nice write-up.
Old Oct 10, 2006 | 11:29 PM
CLOUT's Avatar
Default Re: (P Nut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P Nut &raquo;</TD></TR><TR><TD CLASS="quote">Hey, a little Simple Green's not going to hurt that engine bay.
Nice write-up.</TD></TR></TABLE>
hahah same with cleaning those mf10's
Old Oct 11, 2006 | 12:10 AM
sachse_s2000's Avatar
Default Re: [FAQ/DIY] S2000 NRG X strut brace install (rukawa1one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rukawa1one &raquo;</TD></TR><TR><TD CLASS="quote">
haha nice shoes i had them when i was in 6th grade
BTW nice write up
Old Oct 12, 2006 | 04:51 AM
VTECisSeXY's Avatar
*insert here*
hows the car feel now?
Old Oct 12, 2006 | 05:03 AM
Francesco's Avatar
Default Re: (VTECisSeXY)
I want the ASM one.
Old Oct 12, 2006 | 12:27 PM
gabspeed's Avatar
nice, selling the Cusco bar?
Old Oct 12, 2006 | 12:38 PM
Infinity_Racer's Avatar
looks good...feel any difference?
Old Oct 12, 2006 | 12:50 PM
iam7head's Avatar
Default Re: [FAQ/DIY] S2000 NRG X strut brace install (Infinity_Racer)
it doesn't comes with a extended bolts right?
Old Oct 12, 2006 | 01:37 PM
JDM knowledge's Avatar
Default Re: (Francesco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">
I want the ASM one.</TD></TR></TABLE>
same
So any noticable understeer?
Old Oct 12, 2006 | 06:03 PM
rukawa1one's Avatar
Hey guys, thanks for the replies. I have not test driven the car yet, cuz its not mine! I just put the bar on for him. He said that next time he comes I can test it out in at turnbull canyon, which is minutes away from me.
Sorry the cusco unit is already sold!
Old Oct 12, 2006 | 06:07 PM
Francesco's Avatar
Default Re: (JDM knowledge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM knowledge &raquo;</TD></TR><TR><TD CLASS="quote">
same
So any noticable understeer?</TD></TR></TABLE>
you have sway bars? i want to get the swift ones.
Old Oct 12, 2006 | 06:09 PM
tmkpres's Avatar
Nice write up and pics.
Now clean the engine bay
Old Oct 12, 2006 | 10:02 PM
llxzxll's Avatar
Default Re: [FAQ/DIY] S2000 NRG X strut brace install (tmkpres)
looks like a good piece.
Old Oct 13, 2006 | 05:11 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">you have sway bars? i want to get the swift ones.</TD></TR></TABLE>
the stock ones. I want the Cusco ones and the Cusco floor bar. That **** is gonna be stiff as hell. Maybe too stiff
Old Oct 13, 2006 | 05:53 AM
Francesco's Avatar
the stock ones. I want the Cusco ones and the Cusco floor bar. That **** is gonna be stiff as hell. Maybe too stiff </TD></TR></TABLE>
i wanted cusco in the begining, but im impressed with the swift so i want to try them out. the 3pc. floor bar is nice, i may get that down the road. i kinda want new coilovers next year first.
Old Oct 13, 2006 | 06:22 AM
mytoesarecrazy's Avatar
was curious if the X brace will worth with J's carbon fiber intake system?
http://www.aj-racing.com/catal...age=1
Old Oct 13, 2006 | 09:06 AM
Shadow_S2K's Avatar
Default Re: [FAQ/DIY] S2000 NRG X strut brace install (mytoesarecrazy)
Yes it will
Old Oct 13, 2006 | 07:41 PM
spoon063's Avatar
Default Re: [FAQ/DIY] S2000 NRG X strut brace install (Shadow_S2K)
im assuming the stock airbox setup fits back in just fine ?
Old Oct 13, 2006 | 09:34 PM
rukawa1one's Avatar
Default Re: [FAQ/DIY] S2000 NRG X strut brace install (spoon063)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon063 &raquo;</TD></TR><TR><TD CLASS="quote">im assuming the stock airbox setup fits back in just fine ?</TD></TR></TABLE>
Yes, dont the pics show that it does?
Old Oct 14, 2006 | 07:12 AM
spoon063's Avatar
Yes, dont the pics show that it does?</TD></TR></TABLE>
oh my bad, of course those were the only pics that didnt load when i fist read the thread
Old Oct 16, 2006 | 11:44 PM
BlueIntegraBoy's Avatar
Looking good. Looks like it a well made item.
ziptie
Suspension & Brakes
Jun 6, 2007 11:59 PM
RobbieG35
May 19, 2006 08:51 AM
spooniq
Honda S2000
Apr 23, 2005 07:40 PM
jdmspoonitr
Nov 22, 2002 09:23 AM
