I picked up a Tig welder, I think im off to a good start
Old Oct 10, 2006 | 01:32 PM
vsmhatched's Avatar
Default I picked up a Tig welder, I think im off to a good start
well, I ended up getting a tig welder, Im in collage and only 20 years old..so I couldnt afford any baller status welder, but got a lincoln 175 tig/stick welder. Well, I've been plaing around with it the last week or so, I've never tigged before this. But I started with aluminum instead of steel. But to get to the point, let me know what you guys think of my progress so far. Give me some pointers or tips if you guys see any.
used.
1/16 4043 filler rod
1/16 pure tungsten
.040 and.060 aluminum
Here's 2 three inch of .040 butt welded together
Some box thing, 2 inches wide by 8 3/4 long. .060 aluminum used
hexagon thing .060 aluminum, 6 inches long and 2 inch sides.
whatcha think???????
Old Oct 10, 2006 | 02:07 PM
Justin Olson's Avatar
Default Re: I picked up a Tig welder, I think im off to a good start (GreyDel)
Very nice so far. The first one looks too hot, but you are making lots of progress.
On aluminum I like to use 3/32" thoriated(red) tungsten. Give it a try.
Justin
Old Oct 10, 2006 | 03:58 PM
david@didrace.com's Avatar
Looks really good, I was about 50x worse when I first started out.
Old Oct 10, 2006 | 06:15 PM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreyDel &raquo;</TD></TR><TR><TD CLASS="quote">Im in collage</TD></TR></TABLE>
oh man, i had to.
looks good though.
Old Oct 10, 2006 | 07:14 PM
Honda Sport's Avatar
how much/where did you get your Lincoln from? I'm interested in getting into Tig welding too but on a tight budget for now.
Old Oct 10, 2006 | 08:08 PM
vsmhatched's Avatar
Default Re: I picked up a Tig welder, I think im off to a good start (Honda Sport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">
oh man, i had to.
looks good though. </TD></TR></TABLE>
LOL, oopsss...well, im in college for cars, not proper grammer and whatnot...lol, anyways...the welder i got from a friend for 400 bucks, Im not really to sure on where to look for one tho??
Old Oct 10, 2006 | 11:53 PM
jaydmcrx's Avatar
The heat looks a bit uncontrolled and soupy almost. But if thats some of your first welds, then your off to a way better start than a lot of people that i have seen. . Looks like you have great mechanical skills, and soon you will find yourself getting better and better, and learning how to control your heat.
Old Oct 11, 2006 | 02:16 PM
vsmhatched's Avatar
so I tried 2% thoriated, I couldnt really tell a difference. But should I grind the end to a ball, since it doesnt really ball up on the end like the Pure tungsten would. Or do I keep it to a point, like if I were welding steel??
Old Oct 11, 2006 | 02:35 PM
Bjorn's Avatar
as stated you need to work on your heat control - pic 2 shows the dark gray scabbing you get when when you completely burn through. Try to get full penetration with a shiny backside or light frosting (looks just like the stuff to the left and right of your beads).
tips - don't even try to get a stacked dime effect, instead just focus entirely on heat-control until you get that down. Keep a consistent arc length - longer arc = more heat, just like a spark plug. On non T-joints, red or green works just as well - I just chamfer the edges of the tungsten - it'll ball up by itself and when it does, keep welding with the ball so you get an understanding of it's effect on arc control.
While yor beginning, don't bother regrinding if you accidentally dip the electrode, just keep the arc going til it cleans itself and get keep going (I realized when starting out, you could keep going even if you dipped several times - I tell you this to just save time while practicing and to get an understanding of how Al welds)
after you master lap welds practice on butts and tees
and remember "practice, practice, practice" is not a slogan for lazy teachers, you really need DOZENS of hours to really get down Al just right
good luck
Old Oct 11, 2006 | 04:06 PM
.RTErnie's Avatar
Default Re: I picked up a Tig welder, I think im off to a good start (Bjorn)
basically.
take a look at how big a piece of aluminum you're welding and think about how long its going to take to raise the temperature...so as the temperature increased you dont need to put as much heat into the piece as before. back off on the pedal as you feel/experience the piece heating up.
Old Oct 11, 2006 | 04:34 PM
tony1's Avatar
LOL, oopsss...well, im in college for cars, not proper grammer and whatnot...</TD></TR></TABLE>
lol, sorry..
Old Oct 11, 2006 | 08:09 PM
vsmhatched's Avatar
Default Re: I picked up a Tig welder, I think im off to a good start (tony1)
thanks for the input everyone
Old Oct 13, 2006 | 01:14 PM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">
lol, sorry.. </TD></TR></TABLE>
How did I know he was going to show up for that!
Old Oct 14, 2006 | 03:22 PM
standbackimapro's Avatar
The beads are too far apart, there suppose to look more like this...
Closer together insures stregnth and reduces chances of pitting
Other than that Very Nice welds for Just starting out tig welding
Old Oct 15, 2006 | 06:00 PM
Laserjock's Avatar
Default Re: (standbackimapro)
aarrggh! Peer pressure made me do it!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by standbackimapro &raquo;</TD></TR><TR><TD CLASS="quote">The beads are too far apart, there suppose to look more like this...
I searched and the closest thing i found was a TIG185. is the 175 an older model if I assume you bought it used?
spell-checked!
Old Oct 16, 2006 | 04:26 AM
RC000E's Avatar
Just rediculous...I can't read with these conditions
Old Oct 16, 2006 | 08:21 PM
Laserjock's Avatar
Default Re: (RC000E)
Viscous psykel!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E &raquo;</TD></TR><TR><TD CLASS="quote">Just rediculous...I can't read <U>with</U> under these conditions </TD></TR></TABLE>
Old Oct 17, 2006 | 07:20 AM
gldndrgn14's Avatar
about you and proper grammer, look at your sig, and your webpage spelling. hahah
http://www.t1racedevelopment.com
Old Oct 17, 2006 | 09:22 AM
Ckjeepin's Avatar
Default Re: I picked up a Tig welder, I think im off to a good start (gldndrgn14)
GRAMMAR
Old Oct 17, 2006 | 10:29 AM
tony1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gldndrgn14 &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.t1racedevelopment.com </TD></TR></TABLE>
What's wrong with it?
Old Oct 17, 2006 | 10:41 AM
.RTErnie's Avatar
He thinks it is spelled developement... proving his ignorance and his solidifying his last place finish at the 2006 Grammar Olypics.
Old Oct 17, 2006 | 11:01 AM
RogueWorks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E &raquo;</TD></TR><TR><TD CLASS="quote">Just rediculous...I can't read with these conditions </TD></TR></TABLE>
ridiculous
Old Oct 17, 2006 | 11:03 AM
RogueWorks's Avatar
Default Re: I picked up a Tig welder, I think im off to a good start (Eric@HorsepowerFreaks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eric@HorsepowerFreaks &raquo;</TD></TR><TR><TD CLASS="quote">He thinks it is spelled developement... proving his ignorance and his solidifying his last place finish at the 2006 Grammar Olypics.</TD></TR></TABLE>
Olympics
Old Oct 17, 2006 | 11:46 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: I picked up a Tig welder, I think im off to a good start (RogueWorks)
pwned
Old Oct 17, 2006 | 12:16 PM
tony1's Avatar
Default Re: I picked up a Tig welder, I think im off to a good start (wantboost)
lol, you guy ar funnie, picking on poeple who cant spel.
