Help Car wont go in gear
Old Oct 10, 2006 | 12:52 PM
Snailed EF's Avatar
Default Help Car wont go in gear
i just put a new stage 4 xtd clutch in my car and it ran and drove fine after instalation. then i just go my license back today so i took it to meet my friends somewhere and it drove fine there prolly bout 10 miles. then when i was leaving i went out to my car and it started fine but when i went to put it in reverse it grinded then i tried 1st through 5th and it wouldnt go in gear but did not grind. there is still pressure on the clutch pedal so i dont think its the throw out bearing. could it be that the clutch just isnt disengaging far enough? i tried turnin the car off puttin it in reverse then stating it and it jumped backwards. any suggestions
Old Oct 10, 2006 | 12:58 PM
89 civic si's Avatar
Default Re: Help Car wont go in gear (Snailed EF)
its time to take the tranny down and figure out what happend, first i would check the fluid level, second i would check the linkage third i would check the clutch cable why did you put a stage 4 clutch in your car just to be curious im not being a dick
Old Oct 10, 2006 | 01:04 PM
Snailed EF's Avatar
turbo time i just thought it would hold up better and i was goint to break it in for the 500 miles b4 put under boost i have had it down twice cause the first throw out bearing they sent me was plastic and got ate up then put theoem back in and ran fine until today
Old Oct 10, 2006 | 01:08 PM
Snailed EF's Avatar
also put plenty of fluid in 2 bottles of fluid to be exact did the same when i took it down to replace the throw out bearing
Old Oct 10, 2006 | 01:11 PM
Default Re: (Snailed EF)
did you check the linkage? and the clutch cable
vtexas936
Transmission & Drivetrain
Nov 25, 2011 05:21 PM
dirtmcgirt79
Sep 12, 2008 07:57 AM
snzh22
Apr 29, 2008 09:22 AM
tenjintuned
Apr 8, 2006 04:18 AM
integ R a
Dec 5, 2004 05:52 PM
