On old friend comes home..
My old friend is back from paint once again..
I think i have the most bent R in the history of Type Rs...
I bought the car crashed " totaled by ins" as a parts car but rebuilt it...
When i got her....
When i was done..
Then the lift thing..
Now......
When i got her....
When i was done..
Now......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R »</TD></TR><TR><TD CLASS="quote">glad to see her back! how did you fix that rear camber?? was it just a bent control arm?</TD></TR></TABLE>
Port a power.........need i say more....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rene M »</TD></TR><TR><TD CLASS="quote">
yes bc I dont know WTF that is
</TD></TR></TABLE>yes bc I dont know WTF that is
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R »</TD></TR><TR><TD CLASS="quote"> yes bc I don't know WTF that is
i second that notion because not all of us are badasses like you in restoring caRs
</TD></TR></TABLE>i second that notion because not all of us are badasses like you in restoring caRs
fair play to you man, you're a soldier, i remember when you posted the thread about it falling off the lift and i was nearly ******* crying for you. nice work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike »</TD></TR><TR><TD CLASS="quote">Good to see it brought back to life again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R »</TD></TR><TR><TD CLASS="quote">yes bc I dont know WTF that is
Lol....
# Industry standard couplers are interchangeable with leading manufacturer’s units.
# Snap together design of extension tubes allows for easy assembly.
# Sturdy extension tubes hold up in even the toughest situations.
# Automatic overload system on pump protects against damage to equipment.
# 10-ton ram with 6" stroke and special piston rod end designed to fit most collision repair set components. Wt., 12 lbs.
# The single-speed pump is ideal for single-acting rams. Developing up to 10,000 psi operating pressure, the pump operates horizontally or vertically in the “down” position. Finger-tip control provides instant release or pumping action. Has a built-in safety overload valve. Ideal for use with OTC Stinger single-acting rams, or similar competitive rams.
# 1/2-ton hydraulic spreader tool has 2" jaws that spread from 5/8" to 3-3/8".
# Includes a sturdy plastic case with wheels for ease of mobility.
# Carries a two-year warranty.
# Weight: 78 Lbs
You can fix anything with it.. I cut the 1/4 out and replaced it the roof was a bitch i had to use a pin gun to pull all of that out.
</TD></TR></TABLE>Lol....
# Weight: 78 Lbs
..and you guys thought it was a coincidence that CW is about the same color as Bondo!
j/k, glad to see you've recovered from dropping that car on your head (almost).
ninja-on-speed edit: Hey Rene, can you bring that magic hammer up here and fix my Prelude? It's a little "bendy".
