Can you switch out the sleeves?
The sleeves to my rears are alot longer than the sleeves in the front, can i switch out the sleeves so i can lower the front more?
ground control coilovers
it wouldnt make a difference. the rears are longer because of the cup shape of the spring perch.
i would drop your shock a little lower in the front wishbone. if you have normal oem type shocks (ie oem, tokico), you need to remove the weld around the brake line collar and remove it.
that will allow you more shock travel and be able to get a bit lower.
https://honda-tech.com/zerothread?id=469485
