no injector pulse
is there any causes for no injector pulse on my 91 civic dx(dual point), the ecu light turns on but then shuts off and doesnt blink so its not throwing any codes as far as i know, what else might cause no injector pulse or is it my ecu
either a sensor in the dist or ur car has a code 13 i think it is which is secondary injector if its bad then replace it if it goes again its ur ecu
Interesting you mention code 16. Half the main relay provides power to the fuel pump. The other half provides power to the injectors that the ECU grounds when it sees a signal from the distributor.
conantech
11
Mar 11, 2011 08:20 AM
allm0torGSR
Apr 30, 2004 05:10 PM
