bad fuel injectors
Old Oct 10, 2006 | 07:41 AM
tmars2's Avatar
Default bad fuel injectors
I have a stock 94 Integra RS with almost 250k miles. The fuel injectors on the 3 and 4 have gone out. Any ideas on why? I dont want to put new ones in if this is going to keep happening. Is there any reason that two would die at the same time?
Modified by tmars2 at 9:40 AM 10/10/2006
Old Oct 10, 2006 | 08:11 AM
orangebarius's Avatar
Default Re: bad fuel injectors (tmars2)
they break over time. i had to replace my cylinder #1 injector at 120,000 miles. not big deal. its really easy and you can find them used for dirt cheap on these forums.
Old Oct 10, 2006 | 11:10 AM
CHONCH2's Avatar
yeah, any OBD1 integra or civic injector will work. im currently using OBD1 civic ex injectors in my GSR and having no problems at all.
Old Oct 11, 2006 | 06:14 AM
Default Re: (CHONCH2)
if you do happen to use obd2 injectors (i bought a set by accident) you just have to file down the plastic tabs in order for it to snap into the harness. they will work perfectly after you file them down. but try to get obd1 injectors because it is less work.
i bought a set of 4 on team-integra.net for $10 shipped last yr. check it out, there are always people that upgraded their injectors and have the stock ones lying around.
bigek
Jul 7, 2018 04:29 PM
csmith21
Mar 12, 2013 01:43 AM
tommyj
Sep 7, 2008 03:02 PM
