Rigging the 90/91 Corner lights on an 88/89.
Old Oct 10, 2006 | 05:27 AM
Vovchandr's Avatar
Default Rigging the 90/91 Corner lights on an 88/89.
I know im supposed to have the 90/91 fenders in order to do the "correct swap" for the corner lights. But is there anyway to make shift a mount and just mount and mount them in any good solid way?
Anybody has done this?
If I get the fenders then the moldings wont match, then i'd have to get the doors too, then the 1/4 panel swap w/ body work, and the rear bumper (the front is already a 90/91), and all that swapping just isnt worth the corner lights alone. But if I could do it without swaping the moldings, i'd be all up for it.
Old Oct 10, 2006 | 06:23 AM
em Dot's Avatar
POOPCheeks
Default Re: Rigging the 90/91 Corner lights on an 88/89. (Vovchandr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vovchandr &raquo;</TD></TR><TR><TD CLASS="quote">I know im supposed to have the 90/91 fenders in order to do the "correct swap" for the corner lights. But is there anyway to make shift a mount and just mount and mount them in any good solid way? </TD></TR></TABLE>
i put 91 corners on my 89 crx. you need those tiny clips that the 91 slides into on the fender. taking them off is a little hard without breaking. also i changed the headlights to 91 for the screw hole mount for the 90-91 corners
Old Oct 10, 2006 | 11:22 AM
Vovchandr's Avatar
Default Re: Rigging the 90/91 Corner lights on an 88/89. (em Dot)
so is the headlight change necessary or you just decided to do it to make things easier
Old Oct 10, 2006 | 11:32 AM
wiZCo's Avatar
Stouts 'n' Scotch
Yes, or at least swapping the headlight bracket. The 90-91 is definitely different than the 88-89.
Old Oct 10, 2006 | 11:38 AM
Vovchandr's Avatar
Default Re: Rigging the 90/91 Corner lights on an 88/89. (wiZCo)
Oh well I could use new headlights anyway.
crxaddikt
10
Oct 21, 2013 12:22 AM
jamescb77
Jun 3, 2007 04:38 PM
I Like Hondas
Jun 2, 2006 02:48 PM
cr-rex88
13
Apr 12, 2006 03:49 AM
Riceburner247
Nov 6, 2005 01:26 AM
