turn signal >> foglight conversion anyone?
Old Oct 10, 2006 | 01:47 AM
ethereal2pt2's Avatar
Default turn signal >> foglight conversion anyone? HELP!
does anyone have any insight on converting the bottom turn signals into foglights? if it's possible. my friend owns a 95 accord and we were talking about it the other day. from what i understand is that there's two turn signals per side? and the bottom are just going to waste. used the search engine but all i got was oem fogs or aftermarket. any info on this would be greatly appreciated. if this sounds noob to you please, alt+f4 right now. i dont even own an accord.
Old Oct 10, 2006 | 08:10 AM
eagleclawracing's Avatar
Default Re: turn signal >> foglight conversion anyone? HELP! (`VTEC`)
Well it will take some splicing....But not really worth it becaue that realy will burn up after a while... but all you have to do is send it power threw a toggle.. or you can splice it straight to your head lights
Old Oct 10, 2006 | 11:25 AM
what will burn up after awhile? would it not be cheaper this way than going out and buying an aftermarket or oem fogs? sorry for the noob questions. im not good with headlights nd such.
thanks for the input.
Old Oct 10, 2006 | 11:43 AM
dmurphy2k3's Avatar
Default Re: (`VTEC`)
There's a writeup out there somewhere on it but it isn't on honda-tech. I can't remember the site but its very good and thorough. You might want to try accordinglydone.com or google, its been a while since I've seen it, sorry i can't remember.
Old Oct 10, 2006 | 12:02 PM
iam7head's Avatar
Default Re: (dmurphy2k3)
the reflector for the signal is design to project max amount of light to the car driver in front of you, if you make a fog light with the same reflector, it's a constant glare light, not to mention it will provide anything good in term of light coverage.
retro fit it with something maybe?
Old Oct 10, 2006 | 03:52 PM
Default Re: (iam7head)
Not if u put a fues on it Just try splicing the wires and see what happens
Old Oct 10, 2006 | 06:07 PM
haha im a real noob when it comes to headlights. umm by splicing the wires you mean by splicing the headlight wires to the turn signals right? so they turn on with it. how hard would it be to install a seperate switch to actuate this? anyone know how to do this? or a writeup? thanks a lot.
Old Oct 10, 2006 | 07:36 PM
TheMuffinMan's Avatar
He knows where you live!
Hmm, odd, the only turn signals I have on my car would be the ones on the bumper, the corner lights do not blink. I looked into it for awhile, the best thing to do is get a relay, and get it to be powered on all the time, and then when a ground is received (i'm assuming that's how the turn signal works) It'll trip the relay into flashing it. I just decided against it and went with real fogs
Old Oct 10, 2006 | 07:49 PM
aZnAcCoRd02's Avatar
Default Re: (TheMuffinMan)
you tryin to get your turn signals to turn on with your corner lenses?
like this?
Old Oct 10, 2006 | 09:45 PM
yeah. my friend's gona replace the yellow housings for white ones. but i thought the corner ones were blinkers as well. at least it was for his 95. muffinman if your sides don't do anything, what are they for? you sure they might not just be burned out? as i said i don't even own an accord [ got a lude ] im just basing stuff off what i saw off my buddy's accord. thanks for the help.
Old Oct 10, 2006 | 10:09 PM
haha yep, mine are just corner lights, they just light up (i have blackhoused depos now)but they've never blinked to my knowledge. I thought it was odd myself, but it works for me. I guess it's possible I have maybe a fuse or something burned out for them, but who knows?
Old Oct 11, 2006 | 08:52 AM
Dzaccord's Avatar
I did this mod as well on my 95. I bought a 1157 socket and removed the factory socket and purchased dual filament bulbs as well. Mine light up and blink.
I used this site:
http://www.cryogen97.net/howto/bumperlights.html
It's pretty easy ounce you've gotten started you'll see what needs to be done. Mine have been done for over a year with no problems.
Old Oct 11, 2006 | 09:48 AM
Legendaryyaj's Avatar
Default Re: (Dzaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dzaccord &raquo;</TD></TR><TR><TD CLASS="quote">I did this mod as well on my 95. I bought a 1157 socket and removed the factory socket and purchased dual filament bulbs as well. Mine light up and blink.
I used this site:
It's pretty easy ounce you've gotten started you'll see what needs to be done. Mine have been done for over a year with no problems.</TD></TR></TABLE>
He's on it. You have to use a 1157 socket to take the dual filament bulb. The burning out is caused by using one filament and it overheats.
It wont be a foglight but more or less like a parking light. The corners on the 5th gens should blink. Theres two bulbs and the outer ones blink in conjunction to the bottom ones. They alternate blinking. The two inner ones in the corner dont blink at all.
If you switch to the JDM corners theres only one bulb and it doesnt blink.
Old Oct 11, 2006 | 09:56 AM
Hmmm, interesting, wonder if I do have a fuse out or something. My corners stock and DEPO haven't blinked since I can remember, but I know the bulbs work just fine.
Old Oct 11, 2006 | 10:10 AM
Im pretty sure the corners should blink. Its been awhile since I had my 5th gen.
Old Oct 11, 2006 | 10:11 AM
momstaxi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan &raquo;</TD></TR><TR><TD CLASS="quote">Hmmm, interesting, wonder if I do have a fuse out or something. My corners stock and DEPO haven't blinked since I can remember, but I know the bulbs work just fine. </TD></TR></TABLE>
the corner lights only blink as signal on the 94-95 models. due to the "elongated bumper lense" on the 96-97 they didnt feel it was necessary for the corner light to blink as well
Old Oct 11, 2006 | 10:21 AM
Problem solved! lol thanks momstaxi, I don't think I've ever seen mine blink but I've always wondered
Old Oct 11, 2006 | 12:05 PM
Default Re: (momstaxi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by momstaxi &raquo;</TD></TR><TR><TD CLASS="quote">the corner lights only blink as signal on the 94-95 models. due to the "elongated bumper lense" on the 96-97 they didnt feel it was necessary for the corner light to blink as well</TD></TR></TABLE>
OHhhhh. I didnt know that. I had a 94 so mine blinked.
Old Oct 11, 2006 | 01:08 PM
I used this site:
thanks for the link!
oh and thanks momstaxi for clearing that up.
thanks a lot guys.
hopefully my friend will take the advice and i'll snap some end shots when it's done.
Old Oct 11, 2006 | 05:40 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: turn signal >> foglight conversion anyone? HELP! (eagleclawracing)
I've had mine this way for over 5 years. never had a problem with relays or duel filiment bulbs burning out. Also because of my cars lowered ride height I dont belive I'm blinding any drivers and this really does aid in lighting up the road in front of you.
Old Oct 11, 2006 | 09:49 PM
lookin' good.
jw but how is yours set up?
oh and just a quick question.
how does the dual filament bulbs prevent them from burning out quicker?
cuz my 5th gen has those for the brake lights.
i just replaced them a month ago.
they're the ones where they are on constantly and glow brighter when you press the brake.
thanks.
Modified by `VTEC` at 11:19 PM 10/11/2006
Old Oct 12, 2006 | 07:56 AM
hometheaterman's Avatar
Yup someone already said it but the 94-95 corner lights blink and the 96-97 ones don't. The turn signals on the 96-97 are longer also so you can see those more from the side.
Old Oct 12, 2006 | 09:14 AM
Granted they're larger, I still don't think you can see them from the side haha. And VTEC, it just prevents one filament from being owned for being on 100% and flashing. One would stay on and the other blinks.
Old Oct 12, 2006 | 05:07 PM
ohhhh now gotcha.
makes sense.
alrrite but how about if you disconnect the blinkers and just made them as just lights that are constantly on?
would they benefit still?
Old Oct 12, 2006 | 05:18 PM
If you do that you'll have no blinkers up front and thats illegal.
