problems with my b series swap
Old Oct 9, 2006 | 04:08 PM
hndasofst's Avatar
Default problems with my b series swap
i jsut had a b16a swapped into my 88 rex si and im having 2 issues
1. it shakes like crazy, especially when its revved or the clutch is pushed in, and in idle.
2. throttle response is slow
any suggestions?
Old Oct 9, 2006 | 04:13 PM
Crx Jimmy's Avatar
Default Re: problems with my b series swap (hndasofst)
1.what mounts? make sure the bracket on the rear mount is not touching the crossmember
2. check the timing make sure both cams are set right , some importers throw a new cheap belt on the motors as cheap insurance for them and might have screwed it up
Old Oct 9, 2006 | 04:19 PM
C1CRX's Avatar
Traffic signal tech
Default Re: problems with my b series swap (Crx Jimmy)
sounds like your idle may be set a little too low try adjusting it. About the slow throttle response is it throwing any codes??? Did you do a tune up on it before swapping it in? Check timing, do a compression test, leak down? any of that?? that will tell you how healthy a motor really is. oh and good luck.
Old Oct 9, 2006 | 04:42 PM
hndasofst's Avatar
Default Re: problems with my b series swap (C1CRX)
oh ok thanks,
cuz i had a new timing belt put it so maybe ill check the timing...
and as for the mounts they're new mounts id imagine this would cause the vibration
Old Oct 9, 2006 | 05:38 PM
mahatma's Avatar
yeah with stiff b-mounts your car will rattle & shake in ways you never thought possible......at idle!
Old Oct 9, 2006 | 05:56 PM
LankorDie's Avatar
Loved
Community Favorite
Default Re: problems with my b series swap (mahatma)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma &raquo;</TD></TR><TR><TD CLASS="quote">yeah with stiff b-mounts your car will rattle & shake in ways you never thought possible......at idle!</TD></TR></TABLE>
Werd. What mounts are you using?
I'm going to have to also vote wrong timing/loose mounts.
Old Oct 9, 2006 | 07:30 PM
hndasofst's Avatar
Default Re: problems with my b series swap (LankorDie)
oo ok yae thats what i thought
ummm im not sure wat kind of mounts they but ill post tomorrow wat they are
but now im having "bogging" issues
and my car runs really cold is that normal?
Old Oct 10, 2006 | 05:50 PM
JohnnieChimpo's Avatar
Check your map sensor voltage.
A bad map will cause it to run poorly and vibrate more than normal.
Old Oct 11, 2006 | 08:59 AM
hndasofst's Avatar
Default Re: problems with my b series swap (JohnnieChimpo)
how do i check that...
cuz you know how you check your ecu light wen you switch it to the on position and it beeps if its telling you a code... well my light doesnt even come on....
and for the other question
im using hasport street mounts
Old Oct 11, 2006 | 09:02 AM
89 civic si's Avatar
it obvious you didnt swap the motor who swapped the motor get them to fix it
Old Oct 11, 2006 | 09:16 AM
Loserkidwac's Avatar
Default Re: problems with my b series swap (89 civic si)
Honestly sounds like your firing order is wrong, check to make sure your plug wire are corrects...
Old Oct 12, 2006 | 12:00 PM
hndasofst's Avatar
Default Re: problems with my b series swap (Loserkidwac)
yea i didnt do the swap but thats because i gota killer deal on the engine and install price, lol i see why now haha should have just done it my self
but thats besides the point
i checked firing order plugs are right
ummmm ill have to do the timing
but do you think it could be as simple as a dirty fuel filter or even a sticky throttle?
ive tried everything and i dont know how to fix it...
but the thing is
when it happens i just need to let go of the throttle and then push it harder and it goes away(bogging)?
any one ever heard of this?
Old Oct 12, 2006 | 12:11 PM
2poor2tune's Avatar
my old b16 used to to this but it had hf injectors on it. i think one of them were bad. theck shose out and give them a good cleaning.
92b18eg
45
Jun 12, 2013 05:25 AM
peja43916
Nov 3, 2005 05:53 PM
spyderracing
Aug 27, 2004 08:39 AM
EF-21
Feb 20, 2004 09:18 PM
intekragsr
Mar 21, 2003 10:23 AM
