What is the Best Coil Over Set up to Use
Old Oct 9, 2006 | 03:47 PM
500hpintegra's Avatar
Default What is the Best Coil Over Set up to Use
I have a 95 teg was wondering if you guys could give me some feed back on what coil overs you suggest.
A little info is that it is 500hp to the wheels Not a everyday driver as you probably know use it for street and strip.
Any feed back would be greatly appreciated.
\Hearing alot about these omni I am now using tokico
Old Oct 9, 2006 | 03:53 PM
Racermech's Avatar
Default Re: What is the Best Coil Over Set up to Use (500hpintegra)
I just got a set of K Sports and I am very happy so far!!!
https://honda-tech.com/zerothread?id=1297604
Old Oct 9, 2006 | 04:10 PM
RSX-R's Avatar
Default Re: What is the Best Coil Over Set up to Use (Racermech)
You have 500 wheel and you dont even have coilovers?? if you plan to drag with the car i dont think you can do that with a stock suspension. get koni's and get dampers with like 1000 in the front and 700 in the back to prevent backward rocking of the car. and also get some polyurethane motor inserts in order to rid of it more. but anywayz where is the dyno charts??
Old Oct 10, 2006 | 02:03 PM
No affense but if you finish reading the add you will see I am using tokicos now There alright but times are changen i thought mu syspension should too.
Old Oct 10, 2006 | 02:18 PM
Dartanian's Avatar
For 500 whp, you should look into some Koni Yellow SPSS along with some mighty stiff spring rates. I am not sure what the revalved Konis can handle reliably but the OTS Konis don't handle much over 500 lb/in very well.
crashsvg
Mar 1, 2015 03:08 PM
generalfred
Suspension & Brakes
Sep 16, 2010 04:17 PM
94DCTeg
Acura TSX
Dec 25, 2008 10:58 AM
nvrl8
Sep 10, 2008 02:14 PM
Tru Dynamix
Jan 22, 2003 03:37 PM
