any differnce between a p30 and itr head?
The ITR head is basically just a factory-ported P30 head with different cams and dual valvesprings on the intake side. That's why a P30 head on a GSR block is called a "poor man's Type R".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar »</TD></TR><TR><TD CLASS="quote">what the differnence in the head itself? i mean other than cams and valves and springs. is the itr ported more?</TD></TR></TABLE>
flat dual valve springs on intake and standard (round coil) dual valve springs on exhaust to be exact...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral »</TD></TR><TR><TD CLASS="quote">The ITR head is basically just a factory-ported P30 head with different cams and dual valvesprings on the intake side. That's why a P30 head on a GSR block is called a "poor man's Type R".</TD></TR></TABLE>
still a poor mans type r cause you dont have the high compression pistons with the moly coating. lite weight rods etc...
