blower motor write up ?
Old Oct 9, 2006 | 11:23 AM
nk2k2's Avatar
Default blower motor write up ?
do anyone know were i can find a write up for a blower motor? i need to clean out the spinning fan that is inside that housing. i know that you have to take the glovebox out and all that the but what do i do from there? any help would be awesome. thanks.
Old Oct 9, 2006 | 11:29 AM
89 civic si's Avatar
Default Re: blower motor write up ? (4g4d)
you dont have to take out the glovebox to replace the blower motor, you may have to take the ecu cover off its only three bolts, i had to replace blower motors on my ef and my prelude, they where both filled with leaves. after cleaning it out the motor was still loud but they were not that expensive like 30 dollars or something like that, it is more then easy to replace the blower motor
Old Oct 9, 2006 | 11:33 AM
nk2k2's Avatar
Default Re: blower motor write up ? (89 civic si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89 civic si &raquo;</TD></TR><TR><TD CLASS="quote">you dont have to take out the glovebox to replace the blower motor, you may have to take the ecu cover off its only three bolts, i had to replace blower motors on my ef and my prelude, they where both filled with leaves. after cleaning it out the motor was still loud but they were not that expensive like 30 dollars or something like that, it is more then easy to replace the blower motor</TD></TR></TABLE>
can you guide me the right direction?
pscott3
Oct 9, 2014 09:20 AM
untitled23
Sep 2, 2010 02:56 PM
macrohard
Dec 13, 2007 01:57 AM
