Grinding, Need Help.
Old May 2, 2002 | 08:32 PM
EVIL Hx Coupe's Avatar
Default Grinding, Need Help.
I have a 96 HX ever since I bought the car I found that if I shift quick from 1st to 2nd when I'm above 5,500 Rpms My tranny grinds. It goes into gear fine but it grind on its way to second gear. What could be causing this to happen. I know its not me, beacuse I had a couple of friends drive the car and the samething happened. The car has 52k Miles on it if that matters.
Thanks
Old May 3, 2002 | 04:49 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: Grinding, Need Help. (Boost Pressure)
worn/bent shifterforks or weak motor mounts.
Old May 3, 2002 | 05:47 AM
b19coupe's Avatar
Or worn synchro inside transmission.
[Modified by b19coupe, 2:47 PM 5/3/2002]
Old May 3, 2002 | 06:05 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: Grinding, Need Help. (b19coupe)
have you ever seen a worn synchro on a D tranny?
Didn't think so!
Old May 3, 2002 | 06:07 AM
Spade's Avatar
Default Re: Grinding, Need Help. (Mista Bone)
Hey Mista,
Does anyone out there make shifter forks???
I am starting to grind entering 3rd......thank god I still have 40K on the drivetrain warranty.....
Old May 3, 2002 | 08:04 AM
Red Rocket's Avatar
Default Re: Grinding, Need Help. (Spade)
get a new tranny you can fine them for around $300
Old May 3, 2002 | 08:43 AM
samdawgsol's Avatar
New User
Default Re: Grinding, Need Help. (Red Rocket)
If your tranny messing up with that low a miles on it, someone probably learned to drive their first stick on it and hurt it bad. I did that to my dad's manaul when I learned to drive off it. He had to get a new clutch and tranny 6 months lata.
Although his was a 1500 chevy pickup.
Old May 3, 2002 | 10:24 AM
Default Re: Grinding, Need Help. (samdawgsol)
I took it to a mechanic and he said the sychros are not the problem, he drove the car and said that im not pressing the clutch all the way in before shifting, and also my clutch and my throwout bearings are bad.
b18tegraLS
Aug 21, 2008 10:02 PM
fernruffryders
Dec 8, 2005 11:27 AM
mrwink
Mar 4, 2004 07:42 PM
EVIL Hx Coupe
Dec 13, 2002 01:07 PM
dose
Oct 5, 2002 07:08 AM
