Sunroof slides, but doesn't close shut
1990 Crx Si
When I slide it back it works, slide it forward no problem, but when I try shutting
it, the sunroof doesnt shut ! (stays in tilt position)
The sunroof used to work, but now it doesnt.
The switch is 2 months old !
It cant be a relay since the sunroof slides back and forth....
what can it be ??? <FONT SIZE="15">HELP</FONT>
Modified by Rob. at 12:34 PM 10/9/2006
Modified by Rob. at 1:29 PM 10/9/2006
relay? its behind the main fuse box. My roof would tilt but not slip unless u kept on pressing the switch. Swapped relays and now works perfect
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob. »</TD></TR><TR><TD CLASS="quote">My roof slides, but doesnt tilt or close shut. </TD></TR></TABLE>
relay controls both i believe
I tried reading this but doesnt tell me what the problem is.
http://members.aol.com/zmanscrxsi/crxsunroof.pdf
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob. »</TD></TR><TR><TD CLASS="quote">Once again, it slides forward and backward, but doesnt close down ! </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_ED3 »</TD></TR><TR><TD CLASS="quote">I would look at the mechanical structures of the sunroof assembly.
See if one of the swing/slider arms got stuck off track or something. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsca_crx »</TD></TR><TR><TD CLASS="quote">if it slides forward every time without issue, you have a track/ mechanism problem.</TD></TR></TABLE>
dude read the helms, take your roof liner off and look in there. Did u even check hte relay?
check the white plastic pieces that lift the sunroof. they break all the time. mine was doing the same thing. turns out that one broke and the other the screw fell out. i put the screw back in the one side and could get the other side to stay up it i punched the sunroof from the inside. the i couldn't get the broken side to go down so i would keep a steak knife in the drivers door pocket to shut the broken side.
second pic down is what im talking about.
https://honda-tech.com/zerothread?id=1774801
other wise it might be the limit switch playing tricks on you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 »</TD></TR><TR><TD CLASS="quote">Does the motor whine when it's stuck in that position, or does it lock and stop?</TD></TR></TABLE>
I hear it whining, just seems like its stuck.
i have this problem. cause someone broke in threw my sun roof.
do this i have to do this every time
take your car keys. you see where the rails are. Stick your keys pushign down on it while lifting up on the sunroof slightly it should just shut then. you might have to do it on both sides.
looks like this is the problem Im having
See the off-gold color part at the bottom-right of the track and compare it to the same part at the top-right of the track and you will note that the top part is disconnected
The bottom part:
The top part:
And the missing screw
The bottom part:
The top part:
^haha those are my pics and that's my hand. Yes that's your problem
Also what thread was that out of? I don't remember where I posted it
This guy can confirm:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrtoastyjr »</TD></TR><TR><TD CLASS="quote">check the white plastic pieces that lift the sunroof. they break all the time. mine was doing the same thing. turns out that one broke and the other the screw fell out. i put the screw back in the one side and could get the other side to stay up it i punched the sunroof from the inside. the i couldn't get the broken side to go down so i would keep a steak knife in the drivers door pocket to shut the broken side.
other wise it might be the limit switch playing tricks on you</TD></TR></TABLE>
