Suspension & Brakes Theory, alignment, spring rates....
Function 7 Endlinks... which swaybar bushing?
Old Oct 9, 2006 | 09:58 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Function 7 Endlinks... which swaybar bushing?
Hi.
I'm running a 23mm ITR swaybar on the rear, and the OEM endlinks can't take it, so I upgraded to Function 7 endlinks. The problem here, is the metal collar in the swaybar ends will not accept the larger Function 7 bolt, so I had to remove the sleeve, and those bushings aren't going to last long like that.
What bushing/sleeve should I use here? I searched for a few hours trying to find an answer and no luck...
Old Oct 10, 2006 | 07:02 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Default Re: Function 7 Endlinks... which swaybar bushing? (JDM_Ej)
No one uses Function 7 endlinks?
Old Oct 10, 2006 | 08:58 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Old Oct 11, 2006 | 05:37 AM
Chem Geek's Avatar
I remember some of the people that have ASR subframe braces got 4 metal spacers for the bars, is that the kind of thing you're looking for? I'm not sure if it'll fit the function-7 endlinks, but I hope so as I'm going that route in a couple of weeks.
(here's what I"m talking about https://honda-tech.com/zerothread?id=1452650)
Old Oct 11, 2006 | 06:03 AM
1JDMDOMINICAN's Avatar
In another thread, there is some guy using the BLOX endlinks on his sway bar. try looking at those.
Old Oct 11, 2006 | 06:38 AM
ED9man's Avatar
Did you already buy them? I have a pair I want to get rid of since they didn't work with my stock sway.
Old Oct 11, 2006 | 07:52 AM
hybridmoments's Avatar
i use function 7 arms and endlinks
however i cut off the end of the sway bar where the bushing goes, and welded a 3/16" plate to the sway bar with 3 holes in it for adjustability.
now i just use the proper size bolt along with a few spacers and it works excellent for the last 16 months
Old Oct 12, 2006 | 03:39 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Default Re: Function 7 Endlinks... which swaybar bushing? (hybridmoments)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chem Geek &raquo;</TD></TR><TR><TD CLASS="quote">I remember some of the people that have ASR subframe braces got 4 metal spacers for the bars, is that the kind of thing you're looking for? I'm not sure if it'll fit the function-7 endlinks, but I hope so as I'm going that route in a couple of weeks.
(here's what I"m talking about https://honda-tech.com/zerothread?id=1452650)</TD></TR></TABLE>
That is EXACTLY what I was looking for. Thank you!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ED9man &raquo;</TD></TR><TR><TD CLASS="quote">Did you already buy them? I have a pair I want to get rid of since they didn't work with my stock sway.</TD></TR></TABLE>
Yea, they are already installed. I just know those swaybar bushings will be killed.
Old Nov 27, 2006 | 08:42 AM
DavidR's Avatar
Function7 now makes a bushing for the OEM style swaybars, as shown below:
They are new and will be on the site in a bit, but if you need them, let me know.
Modified by DavidR at 12:49 PM 11/27/2006
Old Nov 27, 2006 | 08:52 AM
hayabusa160's Avatar
i had the same problem. what i did was i emailed asr and ordered the metal bushings. he charged me 15 bucks and they bolted right up.
hondur
Apr 5, 2016 08:23 AM
civexspeedy
33
Mar 23, 2012 02:16 PM
Mr.EM1
Suspension & Brakes
Jul 24, 2008 11:17 PM
CALC!_JUST_du_IT!
Aug 28, 2007 03:19 PM
gamby
May 3, 2004 03:10 PM
