I'm having trouble installing my swaybar. I'm using moog stabilizer bar links
Dur Da Dur
I thought it went:
Nut
swaybar
bushing
washer
linkage
washer
bushing
LCA
bushing
washer
nut
BUT! there's not enough bushings for dat! Each linkage has three washers and two bushings. How the **** do I put this together?!
Nut
swaybar
bushing
washer
linkage
washer
bushing
LCA
bushing
washer
nut
Dur Da Dur
Re: I'm having trouble installing my swaybar. I'm using moog stabilizer bar links
The guy at moog said it goes nut washer bushing washer LCAS bushing washer link swaybar nut.
Seems weird but whatever
Dur Da Dur
Maybe someone on this forum could take a couple pictures of their front swaybar links? I just wanna see how the washers/bushings are attached to the lca and swaybar. The moog dude was acting tarded he couldn't find info and called me back an hour later..
Please and thank you
30 second search reveals....
The upper endlink is found on Civic sway bars and the lower endlink is found on GSRs/ITRs.
Dur Da Dur
The difference between that one and what I've got is that I have one more washer.
Does anyone think i'll have a problem throwing the third washer in a spare fasteners bucket?
Thanks
You only need two washers. I'm surprised they didn't give you enough of the thin washers since those more closely resemble the OEM hardware but it's no bother if the thicker ones work.
The bushings should have the smaller diameter (the necked down portion) inserted into the hole of the LCA then sandwiched by the washers on the outside acting as the buns of the hamburger. The other end of the endlink that secures to the Swaybar is held by just the one flange nut.
I'd take a picture if I could but I just put the car down recently and have been driving it after 6 months on the stands. Not about to put it back up.
JMZ400
10-17-2018 11:47 AM
