I HATE MY HYPER BLINKERS!!! Help!!
Only my driver side blinkers blink fast. It's not because of the bulbs because I replaced both of them. I checked the wiring where it's connected to the socket. I wiggle it around and it still blinks fast. I took the socket from the passenger side and put it in the driver side and still blinks fast. At night, the lighting on the bumper light is really dim. Once in a while, it would blink slow again after I would wash my car. It has to be something faulty going on. Someone once told me it was my blinker relay. I don't know where it's at to check. Any help would be great.
haha. I think there's a fray in the wire somewhere. There was someone on HT before who said he could test out the wiring or something like that to figure out the problem. I lost contact with him so we are back to the same old problems.
fuses under the dash was checked. bulbs are the correct voltage. I can't check the harness after it goes through the engine bay. what fuse is it that I check under the hood?
Its just a big square one. I doubt that is your problem though. When those go bad they either stick on or the slow way down because the bi-metal inside the unit itself will weld itself to the contacts causing them to always be on or if the contacts are corroded they will flash slowly because of the resistance. To me it sounds like a wire shorting out somewhere intermitanly or it might even be in the switch itself.
Good luck with that
Good luck with that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc5_integra »</TD></TR><TR><TD CLASS="quote">Its just a big square one. I doubt that is your problem though. When those go bad they either stick on or the slow way down because the bi-metal inside the unit itself will weld itself to the contacts causing them to always be on or if the contacts are corroded they will flash slowly because of the resistance. To me it sounds like a wire shorting out somewhere intermitanly or it might even be in the switch itself.
Good luck with that
You say the switch, are you talking about the thing you hit up and down to make it signal? I think it's a wire shorting out somewhere too.
Good luck with that
97civic123
25
Feb 10, 2005 06:28 PM
r0c5t4r
Apr 1, 2004 08:33 PM
