from camber kit installation on 98 gsr
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
today since im off i wanted to tackle my camber kit installation. i was hoping my helms manual would have come in the mail, but it didnt, so i need instructions in order to install. i already have a torque wrench and other required tools, so all i need in the instructions. i heard if u have everything layed out, it should only take 30-45 mins per side.
What type of camber kit is it? One that replaces the whole upper control arm or the one that doesn't? It's basically bolt off and bolt on. If it's the whole UCA, then remove the castle nut from the top ball joint. Remove the knuckle from the ball joint. Remove the two nuts from the strut tower. Swap over the bushings. Installation is in reverse.
its the ingalls kit, the one where you have two sets of adjusters for each side. not the fork type.
Here you go...
G3 Ingalls/Sprint-Style Front Camber Kit Install:
http://www.team-integra.net/se...D=909
Check out the rest of the articles on ti.net...lots of good info for integras
well ill let you know. im going to go and buy another torque wrench, one with 1ftlb incriments right now and im going try and do the project either tonite or tomorrow, ill def post some pics
