can't get into gear after new clutch replacement. help if you can. thanks
So i just got my clutch replaced, but when the car is on i can't shift into ANY gear, anyone have any idea whats wrong ? - For example - the car is off , clutch pedal is pressed down , ill be in 1st gear and when i turn on the car , i'll jerk forward. So the clutch isnt disengaging. ANY input/help is welcome at this point. thanks
- shifts threw gears fine when car is off.
- clutch cable adjustment didnt work
- flywheel and pressure plate is fine.
- starts only in neutral.
- shift linkage is fine.
- release fork is working fine
- throw out bearing is fine.
- tranny is fine
- everythings pretty much legit but i still don't know whats causing the problem.
alright late.thanks
- tranny is fine
alright late.thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedworks »</TD></TR><TR><TD CLASS="quote">clutch disc in backwards
sucks!
Pull the inspection plate off and have someone disengage the clutch than examine clearance. Don't try to cram your finger in there though.
sucks!Pull the inspection plate off and have someone disengage the clutch than examine clearance. Don't try to cram your finger in there though.
wrx'n you
22
Oct 26, 2006 06:28 PM
