Deck not giving out sound
Old Oct 8, 2006 | 09:42 PM
TheTealHatch's Avatar
Default Deck not giving out sound
i recently try hooking up a 1200 watt amp 2 channel to my front speakers on to my alpine hu. but it kept blowing fuses on the amp.
so i decided to just forget it and just hook up my speakers to the hu w/o the amp. but now the deck turns on but doesnt give out sound to the speakers.
i checked all the wiring and re did it. and i try changing speakers.. and still the same..
the hu is messed up??
Old Oct 8, 2006 | 09:49 PM
94_DC4's Avatar
Default Re: Deck not giving out sound (ackavong)
Can you draw a diagram of how you wired it?
Old Oct 9, 2006 | 08:44 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ackavong &raquo;</TD></TR><TR><TD CLASS="quote">i recently try hooking up a 1200 watt amp 2 channel to my front speakers on to my alpine hu. but it kept blowing fuses on the amp.
the hu is messed up??</TD></TR></TABLE> Lets see, a 1200W amp on door speakers, amp blows fuses, now HU will not drive speakers???????
The first thing I would check for is blown speaker(s) 94
Old Oct 9, 2006 | 02:22 PM
Default Re: Deck not giving out sound (fcm)
did that.. nothing came up =/ i try using my 6x9 and nothing works
Old Oct 9, 2006 | 02:25 PM
darkspector2.0's Avatar
it sounds like you wired something wrong....
Old Oct 9, 2006 | 02:38 PM
Default Re: (darkspector2.0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkspector2.0 &raquo;</TD></TR><TR><TD CLASS="quote">it sounds like you wired something wrong....</TD></TR></TABLE>
nope. i re did everything. and i made sure i did it right. cause its always worked before but when that amp came in it messed up.
since you said i might have done it wrong. i just re-did one speaker to make sure
again. and still nothing
could it be the deck???
Old Oct 9, 2006 | 02:47 PM
Default Re: (ackavong)
i really need help. ive had no music for about a week already
Old Oct 9, 2006 | 03:03 PM
do you have another deck to try
Old Oct 9, 2006 | 03:29 PM
im trying to get it now.. but you think it could be the deck???
Old Oct 9, 2006 | 04:05 PM
anything is possible
Old Oct 9, 2006 | 04:27 PM
fcm's Avatar
fcm
Old Fart
If you connect the HU directly to speakers you know work and still get no sound then it is a good bet it's the HU, or there is a short someplace, and the HUs protection circuits are keeping it from turning on.
When I say directly I mean directly, disconnect all the HUs speaker leads, make sure that the HU has a good ground, [oem radio harness ground will work for test] and make sure you have power on both the red acc. lead and the yellow constant power lead, again the acc. and constant in the oem radio harness will work for the test, [as long as the fuses are good] then connect one of the speaker outputs to a speaker that you know works.
What is the model number of your Alpine HU? 94
Old Oct 9, 2006 | 04:50 PM
Default Re: (fcm)
its an alpine cde-9843
when i turn on the deck the left speaker pops a little.. but no sound. i try hooking up the speakers straight from the HU but still nothing..
could it be the red and yellow that can cause that?? but im leaning more to the HU being messed up.
Old Oct 9, 2006 | 05:03 PM
turboekcivic's Avatar
you blew the output on the deck.. only thing you can do is put a amp to it.. not a 1200 watt amp.
Old Oct 9, 2006 | 05:14 PM
Default Re: (turboekcivic)
so it wont work?? unless i put an amp to hook up to the speakers??
Old Oct 9, 2006 | 05:35 PM
yup
oh aight thanks. thats alot of help.
so i have to use a smaller amp?? right??
Old Oct 9, 2006 | 06:19 PM
yes but not to small.. a good 4 channel would be good
Old Oct 9, 2006 | 06:26 PM
well im just using front speakers.. i dont have anywhere to put my 6x9.. so whats a good 2 channel for the front speakers?
Old Oct 10, 2006 | 04:29 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ackavong &raquo;</TD></TR><TR><TD CLASS="quote">its an alpine cde-9843
</TD></TR></TABLE> Did you try and connect a speaker directly the the speaker outputs of the HU, without using the cars speaker wire?
A "pop" from the left speaker when you turn on the HU may mean a short on the right side.
Although the outputs may be blown, it can just as well just be the HUs protection circuits that are keeping the internal amp from turning on.
To eliminate a short as the problem, try what I suggested before, disconnect the HU harness from the cars harness, [speaker wires] the red, black and yellow leads can be left connected to the oem radio harness, then using a speaker you know works, connect it directly to the HUs harness speaker leads, making sure non of the other speaker leads touch anything including each other, if you still get nothing, then its the HU, and you will need to fix it or get a new one.
Before anything is connected to the front speakers they need to be checked to make sure they are not shorted out, putting a 1200W amp on 50-75 watt speakers will do that. 94
Old Oct 10, 2006 | 08:26 PM
Default Re: (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Did you try and connect a speaker directly the the speaker outputs of the HU, without using the cars speaker wire?
Before anything is connected to the front speakers they need to be checked to make sure they are not shorted out, putting a 1200W amp on 50-75 watt speakers will do that. 94</TD></TR></TABLE>
yeah i did what you tried.. i took off the wires and connected the HU straight to my speakers w/o going thru all the wires from the doors. and still no sound.
i guess im gonna have to give it to my friends dad so he can fix it for me.
but what turboekcivic said...would it work if i just hooked up a smaller amp to the speakers? or would it still be messed up?
Old Oct 10, 2006 | 10:27 PM
im pretty sure unless you messed up the preouts too but i have never seen that happen b4..
Old Oct 10, 2006 | 10:40 PM
aight ill give it a shot tomorrow or something
Old Oct 11, 2006 | 09:18 AM
fcm's Avatar
fcm
Old Fart
but what turboekcivic said...would it work if i just hooked up a smaller amp to the speakers? or would it still be messed up?</TD></TR></TABLE> the it can only be the speaker you are using or the HU.
Yes in most cases if the HUs internal amps outputs are blown, you can still use the preamp, [RCA] outputs to get a signal to an off-board amp, 94
Old Oct 11, 2006 | 08:05 PM
Default Re: (fcm)
yeah. it was the HU output. cause i just got a deck from a friend and wired it up and it worked and now the left speaker doesnt work. maybe it blew or i just wired it wrong. i was too lazy to figure it out cause its dark. but its good
JohnnyEF
Audio / Security / Video
Nov 26, 2006 12:04 PM
aznd87
Nov 5, 2006 09:54 PM
TheTealHatch
Aug 22, 2006 12:53 PM
Thanks knightsport!
Aug 8, 2005 07:24 AM
FatJoe
Oct 5, 2003 10:12 AM
