Oil light flashing ???
Guest
Posts: n/a
While turning over my H22a4 in an attempt to get it to start (having some issues) I noticed my oil light was flashing while cranking. Is this normal? I have never noticed it before. My oil level is fine, the engine hasn't been run in a couple years. Any ideas?
i think it is just an indication that your oil pressure is low. Are you sure that the oil sending unit is hooked up, i dont know if that would cause that, BUT, it would be a good starting point.
Guest
Posts: n/a
Well, I suppose if it isn't starting oil pressure would definatelly be low. I will let you know once I get it running. Hopefully later today. I need to go buy a 1/2 in breaker bar so I can get my crank pulley off. I am changing my timing components today. Then hopefully she will start.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeFanatic »</TD></TR><TR><TD CLASS="quote">Well, I suppose if it isn't starting oil pressure would definatelly be low. I will let you know once I get it running. Hopefully later today. I need to go buy a 1/2 in breaker bar so I can get my crank pulley off. I am changing my timing components today. Then hopefully she will start. </TD></TR></TABLE>
air tools FTW
air tools FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCityLude »</TD></TR><TR><TD CLASS="quote">I have a 10 gal 4hp compressor (115psi max) and a Matco Quiet Tool 1/2 impact
It wouldn't do it</TD></TR></TABLE>
God damn man, that sucks
Mario.
Dec 23, 2004 09:03 AM
