My oil cap broke after...
Old Oct 8, 2006 | 06:07 PM
HGL1668's Avatar
Default My oil cap broke after...
After a 5 hour long drive, I open my hood, and oil all over the place and the oil cap broke into two pieces, luckly, not many pieces, is that normal, its a ITR oil cap,... did even push the car too hard, but however, hitted the speed limiter of 200 km/ph, on the P73 ecu on a JDM itr motor, just want to know is that normal, and have anyone experience this?
And how can I clean up my engine bay?..!!!!
Old Oct 8, 2006 | 06:12 PM
RagingAngel's Avatar
Default Re: My oil cap broke after... (HGL1668)
check the FAQ on how to clean the engine bay.
Simple green or any engine degreaser is fine.
Refer to the other thread about the oil cap....and no it's not normal for it to break.
Old Oct 8, 2006 | 06:14 PM
HGL1668's Avatar
Default Re: My oil cap broke after... (RagingAngel)
OMG, so if its not normal, whats going on most likely?
Old Oct 8, 2006 | 06:16 PM
refer to the other post.
It is likely it broke because it IS OLD. There are manufacturing tolerances, so I wouldn't be surprised if that plus ...here let me help you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">the cap is plastic....
even if your car is from 2001. It's over or around 5yrs old. Last time I checked, most cars go through hundreds if not thousands of heat cycles + vibrations over its lifetime.
Plastic will fatigue faster than metal.
I have some no name brand alum. oil caps on my car.... because I'm sure they'll last longer than stock and be just as good as the aftermarket caps available for more.</TD></TR></TABLE>
Old Oct 8, 2006 | 06:17 PM
HGL1668's Avatar
OH, thanks
ITR.#1446's Avatar
sounds like maybe the hose coming off the valve cover is clogged or something and your getting too much pressure
Old Oct 8, 2006 | 06:20 PM
Default Re: My oil cap broke after... (ITR.#1446)
Good point....
despite the fact the pressure is supposed to travel from the intake arm towards the valve cover, pressure does reverse because the stock PCV valve, the red valve on the intake manifold (which should be checked also -check it by shaking it, listen for clicking noises which means it is good) doesn't do an adequate job of ventilating crankcase pressure.
Old Oct 8, 2006 | 06:23 PM
HGL1668's Avatar
OMG, you are a genius, I am serious, you might be right, i have been having idleing problem where the car would idle high when moving but normal when in a complete stop, I checked everything and every hose is connected correctly, and all the timing is right, cleaned the IAC, or wherever that calls, and still did not help the problem, you might be right?!!!! how do I check for clog and how to clean them?, I am so excited, other than the valve cover hose, anyother hose might be a problem?
Old Oct 8, 2006 | 06:27 PM
HGL1668's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">Good point....
despite the fact the pressure is supposed to travel from the intake arm towards the valve cover, pressure does reverse because the stock PCV valve, the red valve on the intake manifold (which should be checked also -check it by shaking it, listen for clicking noises which means it is good) doesn't do an adequate job of ventilating crankcase pressure.</TD></TR></TABLE>
I don't get exactly how to check the PCV valve, you said? where is that by the way?
Old Oct 8, 2006 | 06:35 PM
Leo C's Avatar
Night Owl
Tape some plastic bags over the distributor, intake filter ( if aftermarket), fuse box, and battery. Hose everything down, preferably w/ a high-pressure hose, spray it with Engine-Brite or any kind of degreaser, and hose it again. Wipe everything down with a clean rag after this, and tire dressing will clean up your rad. hoses and other plastic/rubber parts.
Old Oct 8, 2006 | 06:37 PM
HGL1668's Avatar
Default Re: My oil cap broke after... (Leofski)
Nice, thanks alot
Old Oct 8, 2006 | 06:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HGL1668 &raquo;</TD></TR><TR><TD CLASS="quote">I don't get exactly how to check the PCV valve, you said? where is that by the way?</TD></TR></TABLE>
excitement pwnz your reading....
Old Oct 8, 2006 | 06:48 PM
HGL1668's Avatar
Sorry, dont' know whats the red valve?
Old Oct 8, 2006 | 07:10 PM
HGL1668's Avatar
I seriously dont' know whats the red valve on the IM?
Old Oct 8, 2006 | 07:24 PM
HGL1668's Avatar
Help, please, still, its mind bogeling to see that cap break in two pieces.... sigh*
Old Oct 8, 2006 | 07:25 PM
HGL1668's Avatar
so, any oil cap suggestions here?, or should I just get a brand new OEM type r one, and fix the hose cloging problem and I will be fine?
Old Oct 8, 2006 | 08:58 PM
HGL1668's Avatar
anyone, help?
Old Oct 8, 2006 | 09:39 PM
jdmspoonitr's Avatar
I have my stock oil cap if you want to buy it for 10 bucks shipped
Old Oct 8, 2006 | 10:01 PM
HGL1668's Avatar
Default Re: My oil cap broke after... (jdmspoonitr)
thanks for the offer, but right now I think its my clogged PCV valve thats causing my oil cap to break due to pressure built up. Besides the valve, Should I or do I have to replace the hose, the L shape hose underneath, (I believe) Anyone have pictures of the hose in a JDM ITR B18C motor? Also, is it possible to have a breather hose clog?
Old Oct 8, 2006 | 10:45 PM
HGL1668's Avatar
what do you guys think?
Old Oct 8, 2006 | 11:26 PM
Nobody is saying much because it's probably late....and since I am the night watchman from the other side of the world along with several others...
I can say that I won't say much till you make the attempt to go and look at your own car for this "red valve" on the intake manifold.
Seriously, just try reading what I've posted about the PCV once more ...slowly....if you have to and it will come to you .... if you're willing to look at your own car after reading it.
Old Oct 8, 2006 | 11:31 PM
HGL1668's Avatar
Default Re: (RagingAngel)
well, I have a JDM ITR motor, not sure if my PCV is red because I did not recall from my memory thats there is a red valve, besides that my valve cover is red, however, i have not looked yet, i will soon tomorrow, thanks
Old Oct 9, 2006 | 02:54 AM
an2ny888's Avatar
Default Re: (HGL1668)
i'll help you, take a look near the injectors
Old Oct 9, 2006 | 09:10 AM
HGL1668's Avatar
Default Re: (an2ny888)
Oh, i found it, but is the red valve the only thing I should change when doing this, or should i change the tube too?
Old Oct 9, 2006 | 12:46 PM
HGL1668's Avatar
Hey, I just got a PCV valve from a Honda Dealership, but its black and they said its the same. So there should be no problem right?, ok, I will install the new valve right now
