Agentjam's engine/CRX FOR SALE - 160whp/125wtq and ~30mpg mixed
Old Oct 8, 2006 | 03:41 PM
AgentJam's Avatar
Default SOLD Agentjam's engine/CRX FOR SALE - 160whp/125wtq and ~30mpg mixed SOLD
SOLD
1988 CRX DX
I'm selling my setup, preferably with the crx although the rear quarters are starting to show rust (again) through the 2 year old paint. It still looks great and gets a lot of looks but I'll have more pics up shortly. I'm getting married in the spring and my fiancee and I need a more practical vehicle...unfortunately!
This car really is a D-series jackpot, and I'd like to sell it complete...meaning you drive it away and do what you wish with it or its parts. Engine is always changed with Mobil 1 tri-synth and Honda filters, ALWAYS! Just did last weekend actually.
It's inspected through May '07.
Dynapack dyno with Builthatch after build...
http://www.d-series.org/forums...14872
Engine:
25,000 miles since build (Runs great and pulls hard!!!)
Tuned by Jeff Evans in Easton, PA
12.25:1 compression
Apexi Power FC controlled with commander and obd1 to obd2a harness (my car's wired obd1)
'91 Si cable transmission with no grinds
160whp/125wtq - dynojet on 94 octane
~30mpg mixed each fill up
MSD ignition/cap/rotor/blaster coil
Walbro 255lph pump
AEM fuel pressure regulator with B&M gauge (new fuel filter)
z10 catchcan for valve cover and block breather
WORKING 134a COLD A/C BABY!!! (belt/system can be removed but I love it)
-homeade 4 gauge grounds/power wires with gold battery connectors
D16y8 head (25,000 miles since build)
-competition Alaniz port/polish/rework/3-angle valve job
-Crower 3 cam with crower hardware
-SMSP racing header
-2.5" mandrel exhaust with test pipe and cat converter (will include both)
-2.5" magnaflow muffler mounted like stock muffler
-Skunk2 cam gear
-new valve seals
-skunk2 intake manifold
-h22 throttle body opened up at ends
-short ram intake with K&N filter (10,000 miles on new filter)
-ARP head studs
-obd1 dist
D16z6 block (25,000 miles since build)
-75.5mm new P29/PM7 pistons
-75.5 overbore/hone (Frank bash race engines)
-shot-peened rods
-8lb act flywheel
-ACT heavy duty clutch, still grabs way hard
-micropolished crank balanced to 10k with pistons/rods, flywheel, pully and pressure plate (Frank bash race engines)
-fresh rebiuld with new honda matched bearings (me)
-all new honda seals/belts/rings, etc.
-new apexi 1.5mm headgasket
-ARP hardware everywhere
Exterior
-Silver paint matched rota slips with honda center caps
-good tires, falken ZE-512 fronts, perrelli rears
-drilled slotted front rotors, new rear drums
-braided stainles brake lines
-2 year old Si steering rack
-10,000 mile old tie rod ends
-25,000 mile old axels
-all urethane bushings, with front LCA's drilled with grease taps installed
-lowered on eibach sportlines and kyb gr2's
-camber set to zero with adj ball joint kit in front and adj upper control arm in rear
Interior
-pioneer cd/wma/mp3 head unit
-boston acoustics speakers in 4 corners
-Total mobile audio 440w rms 4 channel amp
-power FC commander
-keyless entry with trunk pop
-power windows and locks installed
-new carpet and new CRX floor mats
-98 civic center armrest/console installed
I'll be back with more pics, I want to see what you guys can offer. This will be a golden opportunity for someone looking to have a nasty N/A d16 at half of my original cost. Keep in mind, this head alone new with the cam/hardware and work is ~$1500 package alone, plus the power FC, smsp header, skunk2 mani and everything to make it a full swap. This engine is a b18C5 in a d16's body.
Let me know.
Thanks!
Vince
Modified by AgentJam at 11:59 PM 2/3/2007
Old Oct 8, 2006 | 03:45 PM
AgentJam's Avatar
Default Re: Agentjam's engine/CRX FOR SALE - 160whp/125wtq and ~30mpg mixed (AgentJam)
Oh and this engine leaks no oil, and burns ~1/2 quart between 3,000 mile changes, always has. I consider this normal for the compression and catchcan setup. Still solid compression, good gas mileage and power...like the day I got it tuned.
http://www.we-todd-did-racing....x.jpg
Ignore the red wire hanging from under the dash, that's for my headlight buzzer that I was removing.
Thanks!
Vince
Old Oct 9, 2006 | 02:32 AM
AgentJam's Avatar
I'm getting some good feedback on D-series.org, just trying to get more exposure on HT!
Vince
Old Oct 9, 2006 | 04:00 AM
Chronicsinners's Avatar
sick local build
Old Oct 9, 2006 | 08:41 AM
AgentJam's Avatar
Default Re: Agentjam's engine/CRX FOR SALE - 160whp/125wtq and ~30mpg mixed (Chronicsinners)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chronicsinners &raquo;</TD></TR><TR><TD CLASS="quote">sick local build </TD></TR></TABLE>
Thanks for the bump man!
Old Oct 10, 2006 | 02:15 PM
AgentJam's Avatar
up for a quick sale, no one wants to make an offer?
Old Oct 10, 2006 | 05:39 PM
Nigel379's Avatar
Bump for an awesome build.
Old Oct 10, 2006 | 07:25 PM
AgentJam's Avatar
Default Re: Agentjam's engine/CRX FOR SALE - 160whp/125wtq and ~30mpg mixed (Nigel379)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nigel379 &raquo;</TD></TR><TR><TD CLASS="quote">Bump for an awesome build. </TD></TR></TABLE>
Thanks man! I don't want to see it go but it's not much of a family car hehe. I'm hoping another d-series lover will take advantage of this opportunity...I wish somebody was selling this back when I was building!
Old Oct 10, 2006 | 08:10 PM
pimpwagon's Avatar
how much?
Old Oct 11, 2006 | 02:57 AM
AgentJam's Avatar
Default Re: Agentjam's engine/CRX FOR SALE - 160whp/125wtq and ~30mpg mixed (pimpwagon)
I've gotten an offer for $3,000 but haven't seen the money yet. Considering everything that went into it, the dyno numbers, and streetability it's a steal for that price.
Old Oct 11, 2006 | 05:00 PM
sikciv666's Avatar
oman 3gs is a fuggin steal.
Old Oct 11, 2006 | 05:27 PM
AgentJam's Avatar
Default Re: Agentjam's engine/CRX FOR SALE - 160whp/125wtq and ~30mpg mixed (sikciv666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sikciv666 &raquo;</TD></TR><TR><TD CLASS="quote">oman 3gs is a fuggin steal.</TD></TR></TABLE>
Havin fun?
Old Oct 11, 2006 | 05:42 PM
. M i c h a e l's Avatar
dotmichael to you
oh man i want it.
Old Oct 12, 2006 | 11:10 AM
AgentJam's Avatar
Default Re: Agentjam's engine/CRX FOR SALE - 160whp/125wtq and ~30mpg mixed (. M i c h a e l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by . M i c h a e l &raquo;</TD></TR><TR><TD CLASS="quote">oh man i want it.</TD></TR></TABLE>
Old Oct 12, 2006 | 05:58 PM
sikciv666's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AgentJam &raquo;</TD></TR><TR><TD CLASS="quote">
Havin fun? </TD></TR></TABLE>
always am.
Old Oct 15, 2006 | 04:41 PM
pimpwagon's Avatar
is it still for sale? what are this cars chances of passing a nys. inspection?
Old Oct 15, 2006 | 05:53 PM
AgentJam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pimpwagon &raquo;</TD></TR><TR><TD CLASS="quote">is it still for sale? what are this cars chances of passing a nys. inspection? </TD></TR></TABLE>
Yep, still for sale...last offer fell through.
Good quesiton, I'm not too familiar with NY's emmissions laws but PA's inspection is rather tough (i think). I've been having it pass legally... A local tuner takes it to a shop and tunes it to pass on the dyno. Advances the timing and drops the fuel pressure. Checks everything else over, tires, brakes, etc.. Then he adjusts the tune back before leaving.
Thanks,
Vince
Old Oct 15, 2006 | 07:55 PM
Loaded Butane's Avatar
Nice Build and CRX
Old Oct 17, 2006 | 11:58 AM
AgentJam's Avatar
Default Re: Agentjam's engine/CRX FOR SALE - 160whp/125wtq and ~30mpg mixed (Loaded Butane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loaded Butane &raquo;</TD></TR><TR><TD CLASS="quote">Nice Build and CRX </TD></TR></TABLE>
Thanks man! Bump for a good home for this build...
Old Oct 18, 2006 | 02:06 PM
the jdmchop's Avatar
would you just sell the motor?
Old Oct 18, 2006 | 03:31 PM
AgentJam's Avatar
Default Re: Agentjam's engine/CRX FOR SALE - 160whp/125wtq and ~30mpg mixed (JDMCHOP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCHOP &raquo;</TD></TR><TR><TD CLASS="quote">would you just sell the motor?</TD></TR></TABLE>
No, I want the someone to drive it away. For $3,000 you could buy everything, pull the engine and swap in a stock d16 for cheap and sell the crx for $2000. I just don't have the time to pull the engine or deal with a shell.
Old Oct 22, 2006 | 04:40 PM
AgentJam's Avatar
UP!!! This thing needs a good home!
Old Oct 25, 2006 | 08:29 AM
AgentJam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AgentJam &raquo;</TD></TR><TR><TD CLASS="quote">UP!!! This thing needs a good home! </TD></TR></TABLE>
Old Oct 25, 2006 | 11:22 AM
AgentJam's Avatar
Ohh yeah, and did I mention I have a 96-00 civic helms manual, and all the boxes/manuals for the head unit, speakers, 4-channel amp, Power FC and commander? They come with the car...
New plugs and oil changed with mobil1 synth and honda filter 500 miles ago, valve lash checked and adjusted 3 months ago...
Just some more info
Old Oct 25, 2006 | 12:00 PM
J98EX's Avatar
bump because I miss my rex. shame your not closer
