Help.......
My abs light is on..........i changed my brakes and all..........why is the light still on...........does anyone no what is wrong and how i can fix this problem or even just take the light off?
What year is the car? If it's 94-97 the ABS has its own fluid reservoir.
My ABS light was on for the longest time, ABS didn't work, and I thought it was some wierd electrical problem. Then one time I looked in the ABS fuse box and found one blown, replaced and problem solved.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeeSeaTooGsR »</TD></TR><TR><TD CLASS="quote">My abs light isnt on but it will kick in right before i come to a complete stop every time. WTF?
Abs blows.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Red.EM2 »</TD></TR><TR><TD CLASS="quote">Check your brake fluid level.
90% of the time, that is the problem.</TD></TR></TABLE>
It doesn't blow, it is telling you something is wrong. And probably the only reason it does that when you stop is mor than likely because your fluid is low. Check it.
-DC2-
Aug 6, 2008 08:53 AM
