Help.......
Old Oct 8, 2006 | 03:37 PM
SlammedBlackGSR's Avatar
Default Help.......
My abs light is on..........i changed my brakes and all..........why is the light still on...........does anyone no what is wrong and how i can fix this problem or even just take the light off?
Old Oct 8, 2006 | 03:48 PM
Miracle's Avatar
Default Re: Help....... (SlammedBlackGSR)
Check your brake fluid level.
90% of the time, that is the problem.
Old Oct 8, 2006 | 04:38 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
What year is the car? If it's 94-97 the ABS has its own fluid reservoir.
My ABS light was on for the longest time, ABS didn't work, and I thought it was some wierd electrical problem. Then one time I looked in the ABS fuse box and found one blown, replaced and problem solved.
Old Oct 8, 2006 | 05:07 PM
Uncle Willie's Avatar
Default Re: (PatrickGSR94)
My abs light isnt on but it will kick in right before i come to a complete stop every time. WTF?
Abs blows.
Old Oct 8, 2006 | 05:09 PM
Miracle's Avatar
Default Re: (DeeSeaTooGsR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeeSeaTooGsR &raquo;</TD></TR><TR><TD CLASS="quote">My abs light isnt on but it will kick in right before i come to a complete stop every time. WTF?
Abs blows.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Red.EM2 &raquo;</TD></TR><TR><TD CLASS="quote">Check your brake fluid level.
90% of the time, that is the problem.</TD></TR></TABLE>
It doesn't blow, it is telling you something is wrong. And probably the only reason it does that when you stop is mor than likely because your fluid is low. Check it.
Old Oct 8, 2006 | 08:40 PM
my car is 95 gsr............thanks alot guys for the help
-DC2-
Aug 6, 2008 08:53 AM
ferngsr
Jun 11, 2006 04:29 PM
redINTEGRAdriver
Jan 31, 2005 12:01 PM
V-Thang
Jun 21, 2004 10:56 AM
Lost Type R
Mar 22, 2003 07:32 PM
