transmission fill bolt on 90 crx si
Is it the one in the wheel well above the drain plug or on top under the starter? I just don't want to open something and mess up a seal or have somthing fly out. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s10cky »</TD></TR><TR><TD CLASS="quote">I like to remove that bolt. and then remove the back up switch bolt and harness. fill there and wait untill the fluid levels with the actual fill hole. easier imo</TD></TR></TABLE>
WAY EASIER
WAY EASIER
ok thank
I got the fluid in the trans and all I have to do is get the exhaust back on, the radiator filled, get it started and check for leaks. Then I get to see if the clutch will work Thanks for the help.
http://www.hondaautomotivepart...2.gif
bolt #11 in this photo shows the location of the hole for you to fill your trans fluid......good luck
r90crxhf
Aug 19, 2011 04:24 PM
doom26464
Jun 18, 2008 07:10 PM
