HX to EX
Old May 2, 2002 | 06:55 PM
DragII's Avatar
25 Year Member
Default HX to EX
this is just a hypothetical, but wouldn't putting an ex head on an HX be a true bolt on affair, the block should already be set to deliver oil to the head since the HX is vtec too, and wiring would be a non issue as well....maybe a vafc to change fuel settings, and vtec engagement point, or just an ex ecu.
just out of curiosity.....anyone see any issues with that.
Old May 2, 2002 | 07:36 PM
RR98DX's Avatar
Default Re: HX to EX (SuperDragII)
ex head will bolt the he HX block like it was ment to be there. no oil lines needed. it would be better to get a EX ecu, but your HX ecu will run it just fine (may be a lil to lean though).
Old May 3, 2002 | 05:00 PM
DragII's Avatar
25 Year Member
Default Re: HX to EX (95CivicSi)
ya I figured as much.
Old May 3, 2002 | 05:03 PM
JV's Avatar
JV
Who?
What kinda power could you expect out of such a "swap"..........?
Old May 3, 2002 | 05:06 PM
DragII's Avatar
25 Year Member
Default Re: HX to EX (JV)
I'm thinking it would be slightly higher than the ex since you will have much more top end, and and the HX aleady makes 115hp
Old May 3, 2002 | 05:22 PM
mantic6t9's Avatar
hmm do they both have the same internals?
Old May 3, 2002 | 05:28 PM
RR98DX's Avatar
Default Re: HX to EX (mantic6t9)
HX's vtec-e just activates the 4 extra valves. when its not in vtec it just runs on 12 valves.
EX's is like dohc vtec (higher lift and duration) but it only works on the intake valves. all 16 valves work all the time in the EX
in japan they released 3-stage vtec which is a combination of the two. it was nuts cause it required 2 vtec solenoids.
Old May 3, 2002 | 05:56 PM
DragII's Avatar
25 Year Member
I think he meant pistons/rods
Old May 4, 2002 | 08:30 AM
EVIL Hx Coupe's Avatar
will an HX make more power on a ex ecu???
[Modified by Boost Pressure, 9:30 AM 5/4/2002]
Old May 4, 2002 | 11:50 AM
DragII's Avatar
25 Year Member
Default Re: HX to EX (Boost Pressure)
Stock HX....no....because the HX valve train is completely differant, and vtec activates far sooner than on an ex
dlee1988
Sep 7, 2007 05:10 PM
BlueRex12
Oct 21, 2005 05:54 PM
mushu315
14
Mar 30, 2005 10:16 PM
Xxcivic99xX
Aug 4, 2004 06:25 AM
xcivic_ex
May 13, 2002 07:20 PM
