LS head on B20 block, head gasket leak.
Old Oct 8, 2006 | 10:33 AM
2ndgentegracer's Avatar
Default LS head on B20 block, head gasket leak.
I bought a B20B4 block with high compression endyn pistons, and eagles rods in it. I mated it with my stock LS head.
I didn't have the head milled and just tossed it back on the new block. Now it has a headgasket leak, I bought ARP headstuds for the LS head, but they didn't help any. I know its leaking at the gasket because theres coolant in the oil. And it blows thick white smoke that will linger in the air for awhile.
Next on the list is to take the head off and get it milled and put another gasket on. Anyone have any other insight on what else could be a problem.
I was wondering if I would have any piston slap with the high compression pistons. The block was used for a B20/VTEC set up before I bought it. It had a GSR head on it.
TIA
Old Oct 8, 2006 | 01:16 PM
projectTeG's Avatar
any crack in the sleeves? you might need to get the head or the block milled.
Old Oct 9, 2006 | 07:24 PM
P@sscard's Avatar
take the head of and get it resurface and get a new head gasket and make sure u torque it to the right torque or else it will keep leaking
dE.fUsEd
May 11, 2013 05:33 AM
Nick_Cartwright
Apr 4, 2013 08:55 AM
90civic-ZC
Oct 31, 2012 06:15 PM
strike1545
May 24, 2010 10:42 AM
Mo_Spec
Dec 10, 2004 12:11 AM
