Few new pics and some tire pressure questions...
Well start off w/ the questions. For those with the new Azenis what tire pressures are you running on the street? Also for the RA1 users what cold tire pressures are you running? I killed one of mine a little sooner than I expected (corded the outside of the tire), not sure if I'm overdriving the car or my pressures are off. Was running 25 psi cold and uhh too lazy to check hot
LOL TIA homays
Getting ready to go the MO in a couple weeks so of course here's the obligatory wax job and pixors
Not the best but hope you guys like em
LOL TIA homays
Those wheels look familiar
No experience with Azenis, but I found that 24f/26r cold in the RA1 225/45/15 worked best for me at Mid-Ohio. My car weighs 2410-2420 lbs with me in it and 1/4 tank.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr »</TD></TR><TR><TD CLASS="quote">no pics from room 206????</TD></TR></TABLE>
If I tried to enter room 206 w/o an anti-ghey suit my skin would be eaten off
I've been running 31-32 Psi on two sets of RT-615s, the first set lasted around 15K mi and 4-5 HPDEs
Cold temperatures, usually start at 32 front cold 31 rear cold for the track as well.
Sick pics Chris as always!
Cold temperatures, usually start at 32 front cold 31 rear cold for the track as well. Sick pics Chris as always!
very excellente pictars of ur car
last one is nice
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES »</TD></TR><TR><TD CLASS="quote"> the first set lasted around 15K mi and 4-5 HPDEs </TD></TR></TABLE>
wow.. i was thinking about getting a new set before expo 7.. hopefully mine will have the same life expectancy
last one is nice
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris93Si »</TD></TR><TR><TD CLASS="quote"> Also for the RA1 users what cold tire pressures are you running? I killed one of mine a little sooner than I expected (corded the outside of the tire), not sure if I'm overdriving the car or my pressures are off. Was running 25 psi cold and uhh too lazy to check hot
LOL TIA homays
Might also be helpful to list suspension and alignment settings.
LOL TIA homays
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg »</TD></TR><TR><TD CLASS="quote">
Might also be helpful to list suspension and alignment settings. </TD></TR></TABLE>
Didn't think of that.
Ummmm if I remember correctly about 1.8 degrees neg. camber on both sides front and around 1.2 degrees neg. camber in rear. Total of 1/8" toe in front and zero toe in rear. Zeal B2 susp, 10k springs front and 6k springs rear. Car weighs 2640ish w/ me in it. What you guys think?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris93Si »</TD></TR><TR><TD CLASS="quote">Ummmm if I remember correctly about 1.8 degrees neg. camber on both sides front and around 1.2 degrees neg. camber in rear. Total of 1/8" toe in front and zero toe in rear. Zeal B2 susp, 10k springs front and 6k springs rear. Car weighs 2640ish w/ me in it. What you guys think?</TD></TR></TABLE>
Not speaking of tire wear, but only performance, you're going to want/need a LOT more negative camber when running the RA1. They like -3.0 or more. Toe settings look good to me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Back in Black »</TD></TR><TR><TD CLASS="quote">
Yah I'd definitely like more but no camber kit yet
</TD></TR></TABLE>Yah I'd definitely like more but no camber kit yet
geebus.... room tooOhsix still the talk months after Exbo
Chris... bad-*** pics as always bro
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon D »</TD></TR><TR><TD CLASS="quote">geebus.... room tooOhsix still the talk months after Exbo
You guys made a hell of an impression on everyone.
</TD></TR></TABLE>You guys made a hell of an impression on everyone.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 »</TD></TR><TR><TD CLASS="quote">For street 33-34 front, 33-34 rear works fine.</TD></TR></TABLE>
yeah, same here, except one or two psi lower in the rear
LOL! Here's a shot from outside room 201
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr »</TD></TR><TR><TD CLASS="quote">Please ditch the JDM spring rates....
< More than willing to switch to a set of RAs w/ better spring rates donated by P1
</TD></TR></TABLE>< More than willing to switch to a set of RAs w/ better spring rates donated by P1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris93Si »</TD></TR><TR><TD CLASS="quote">< More than willing to switch to a set of RAs w/ better spring rates donated by P1
just get some 10-12k springs for the rear. Problem solved
</TD></TR></TABLE>just get some 10-12k springs for the rear. Problem solved
What about some REs?
Great pictures AS ALWAYS. Looks like you added a wideangle
</TD></TR></TABLE>What about some REs?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warwagon »</TD></TR><TR><TD CLASS="quote">i even see one of those ghey *** white lenses</TD></TR></TABLE>
You're just hating cause not only did you get rid of your <FONT COLOR="red">R</FONT>s you got rid of your <FONT COLOR="red">L</FONT>s
