H22 shortblock+F23 SOHC head
Old Oct 8, 2006 | 07:50 AM
DC4_MADMAN's Avatar
Default H22 shortblock+F23 SOHC head
Anyone ever done this? According to zeal autowerks calc it would produce around 10.5:1 CR single cammer.
Would anything special need to be done to the head or block to get it to work?
Old Oct 8, 2006 | 10:29 AM
PirateMcFred's Avatar
Default Re: H22 shortblock+F23 SOHC head (DC4_MADMAN)
It probably has not been done. On the timing belt side fo the engine there are some oil drains that allow oil of the H23/H22 head drain oil back to the block and those ports are not on the F23 head. If you can find a H22/23 head gasket and compare to your F23 HG you will see what I am talking about. If you plug those drains you can swap the head no problem (except adapting the timing belt to he proper set of pulleys F23, H23 or H22)
Pirate
Old Oct 8, 2006 | 11:29 AM
DC4_MADMAN's Avatar
Default Re: H22 shortblock+F23 SOHC head (PirateMcFred)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred &raquo;</TD></TR><TR><TD CLASS="quote">It probably has not been done. On the timing belt side fo the engine there are some oil drains that allow oil of the H23/H22 head drain oil back to the block and those ports are not on the F23 head. If you can find a H22/23 head gasket and compare to your F23 HG you will see what I am talking about. If you plug those drains you can swap the head no problem (except adapting the timing belt to he proper set of pulleys F23, H23 or H22)
Pirate</TD></TR></TABLE>
So, block off ports in head, use F23 timing belt. What about timing pulleys, oil pump and water pump? Would thsoe need to be swapped out for F23 peices or will the H22 parts be ok to use?
Old Oct 8, 2006 | 01:22 PM
v4lu3s's Avatar
RTFM
from my comparison of block to block it owuld be most likley blocking off drain holes in the block.
Old Oct 8, 2006 | 02:08 PM
prelittlelude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC4_MADMAN &raquo;</TD></TR><TR><TD CLASS="quote">
So, block off ports in head, use F23 timing belt. What about timing pulleys, oil pump and water pump? Would thsoe need to be swapped out for F23 peices or will the H22 parts be ok to use?</TD></TR></TABLE>
no you have to block the oil ports on the BLOCK, and this is going to be more difficult because the holes are not uniform. when going from a f block to a H head the holes in the H head are smooth and round making for an easy insert of a plug.
you will have to use a f series oil pump and a f series water pump, h23/f22 lower timing belt gear and sohc timing belt
Old Oct 8, 2006 | 02:16 PM
DC4_MADMAN's Avatar
Default Re: H22 shortblock+F23 SOHC head (prelittlelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude &raquo;</TD></TR><TR><TD CLASS="quote">
you will have to use a f series oil pump and a f series water pump, h23/f22 lower timing belt gear and sohc timing belt </TD></TR></TABLE>
And the same if I were to use an F22 Vtec head? So the biggest problem will be plugging the holes in the block. If I cant use a plug, any suggestions on plugging those holes?
Old Oct 8, 2006 | 02:22 PM
And the same if I were to use an F22 Vtec head? So the biggest problem will be plugging the holes in the block. If I cant use a plug, any suggestions on plugging those holes?</TD></TR></TABLE>
all f22 heads lack the oil drain on that side,
i don't know the best method, weld, epoxy ?
Old Oct 8, 2006 | 02:35 PM
fastludeh22's Avatar
well in the case of the h head f block you have to plug cause it drains into nothing, but in the case of the f head h block i dont see a problem in leaving the holes open. i guess just use the f head gasket? these are all guesses...
BUT the BIGGEST question is WHY? in the case of h head f block it is a big upgrade. but putting a f head on a h block is a downgrade. i mean h22a1 has 10:1 and h22a has 10.6:1 so wont really gain anything there. you will lose however in the breathing department.
if its u just got a f head laying around, pm me i have an extra h22 head laying around. hell i have a turn key full swap im bout to sell...
Old Oct 8, 2006 | 02:36 PM
DC4_MADMAN's Avatar
i don't know the best method, weld, epoxy ?</TD></TR></TABLE>
Cool, thanks for all the info.
Use the F22\23 HG or the H22 HG?
g22kiddos
Dec 4, 2008 05:13 AM
NightMare
Oct 25, 2006 09:36 PM
yellow4dr
Dec 19, 2004 06:28 AM
FB in SA
Apr 22, 2002 08:20 PM
