Help Tach Problem
Old May 2, 2002 | 06:40 PM
B20zvtecek's Avatar
Default Help Tach Problem
I own an 89 civic Si . Recently my tach needle has been jumping around like crazy. i mean below 4000 rpms its normal , but when i floor it the needle will jump instantly from 4400 -8000.
So i never know what rpm im at. For a while i thought it was the clutch slippin but also in neutral when i rev past 4000 rpm itll start to jump around like crazy.
any Help would highly be appreciated Thanks
[Modified by B20zvtecek, 3:42 AM 5/3/2002]
Old May 2, 2002 | 06:43 PM
89 CRX SI's Avatar
Default Re: Help Tach Problem (B20zvtecek)
umm new tach out of a cluster. Check mitchell island down in surrey cause they got a lot of cheap wreckers down there. It is right before the oak street braidge check the map for stevensons road.
Yeah getr a new one cause my buddies 78 civic 1g always spun 3 times around backwards on start up and shut down.
Good luck
Old May 2, 2002 | 07:33 PM
xXx Justin xXx's Avatar
it sounds like a problem i used to have with my old crx. the plug wires were getting interferrence with the coil somehow or something. causing it to read irratic rpms....but new crx have internal coils...so ??????????? just a thought. good luck
Old May 3, 2002 | 05:52 AM
keithv's Avatar
Default Re: Help Tach Problem (The dx-R CRX)
check the ignitor on your distributor. i tightened the screws on mine and it worked much better...
Old May 3, 2002 | 06:03 AM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: Help Tach Problem (breaka_1_9)
yup. it's the ignitor. tighten the connections, there's four.
Old May 3, 2002 | 06:06 AM
Trinity's Avatar
Default Re: Help Tach Problem (HoMoCo FoLife)
well the bearing in his dizzy could be bad too. My bearing went out on my way up ti philly and it was doing this, jumping around the whole time. When we took the dizzy apart the thing had locked up so it could be that too.
Old May 3, 2002 | 07:19 AM
Mugen Dom's Avatar
Default Re: Help Tach Problem (Trinity)
id say igniter get one from a junkyard just goto any civic 88-91 or teg 88-89 basically and open the distributer in a dx even and take the igniter off its easy and small enough to not pay for when u buy somethig else
cyberjunkie
Aug 5, 2004 04:00 PM
Jester88Si
12
Jun 13, 2004 12:59 PM
Mantis88ls
May 23, 2004 09:13 PM
B20zvtecek
Jun 22, 2002 10:46 PM
REDBARON
10
Sep 6, 2001 05:01 AM
