Want to built a fast k20 with k24 block to drive 9s
Old Oct 8, 2006 | 04:39 AM
Klappi's Avatar
Default Want to built a fast k20 with k24 block to drive 9s
Hello boys can you helped me to get the parts i need for my projekt.
Or how can i get them.
I thought to buy a k24 bensen block or golden eagle but i will here on you what is better.
Old Oct 8, 2006 | 05:10 AM
DaveF's Avatar
Default Re: Want to built a fast k20 with k24 block to drive 9s (Klappi)
you cant go wrong with GE or Bensons. it just comes down to how much you want to spend on your project....
get the basics....
sleeves/rods/pistons
valves/springs/retainers
thats a good starting point.
we have been putting our Golden Eagle sleeved B series engines through a shiton of abuse and never had a problem with them.
Modified by dturbocivic at 10:51 AM 10/8/2006
Old Oct 8, 2006 | 05:20 AM
Klappi's Avatar
Default Re: Want to built a fast k20 with k24 block to drive 9s (dturbocivic)
Oh thats nice pm sent.
Old Oct 8, 2006 | 06:45 AM
Nikos's Avatar
It is not going to be that easy, but good luck! All of the teams, that went in the 9s, had a a lot of research and development. It is not as easy as it seems, unless you car weighs 1300 lbs
Old Oct 8, 2006 | 11:09 AM
SpeedDreamz.com's Avatar
Default Re: Want to built a fast k20 with k24 block to drive 9s (Nikos)
Nikos you know it is pretty easy.....with 350whp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nikos &raquo;</TD></TR><TR><TD CLASS="quote">It is not going to be that easy, but good luck! All of the teams, that went in the 9s, had a a lot of research and development. It is not as easy as it seems, unless you car weighs 1300 lbs </TD></TR></TABLE>
Old Oct 8, 2006 | 11:36 AM
DaveF's Avatar
Default Re: Want to built a fast k20 with k24 block to drive 9s (SpeedDreamz.com)
boost............. never heard of it....
Old Oct 8, 2006 | 01:22 PM
Klappi's Avatar
Hello i heart that b series is better to built on boost.
Can anyone say me what i should do.
We dont have civics here with b18 only with b16.
I would by a fast car from the state but i dont find anyone is perfekt to import.
Search for a civic eg or ek with b18 (i can be built on high whp boost)
Old Oct 8, 2006 | 01:32 PM
IT'S ME DAVID's Avatar
NooB
370 hp and a hot rod style light *** chassis you run high 9 low 10.if allmotor.
Old Oct 9, 2006 | 01:29 AM
Klappi's Avatar
Default Re: Want to built a fast k20 with k24 block to drive 9s (IT'S ME DAVID)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT’S ME DAVID &raquo;</TD></TR><TR><TD CLASS="quote">370 hp and a hot rod style light *** chassis you run high 9 low 10.if allmotor.</TD></TR></TABLE>
Yes i think but i want a street car with boost built
Old Oct 9, 2006 | 07:17 AM
af-performance's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Klappi &raquo;</TD></TR><TR><TD CLASS="quote">Hello i heart that b series is better to built on boost.
Search for a civic eg or ek with b18 (i can be built on high whp boost) </TD></TR></TABLE>
If you want a motor that will take you to the 9 second barrier it wont be cheap. Dave is sending you a email now.
We can do it for you, but it will be with the help of IPS. If anybody knows how to run 9's and get the most power outta a k-series its Ron.
Ricky
AF-Performance
Old Oct 9, 2006 | 07:24 AM
Klappi's Avatar
Default Re: Want to built a fast k20 with k24 block to drive 9s (af-performance)
ok thank you for your answer i think i will buit a b18 with boost.
Old Oct 10, 2006 | 01:12 PM
Klappi's Avatar
Hello boys i need help i dont know what is better to built a b18 or k20?
What can i built with a b18 and how much and what can i built with a k20 and how much will it cost.
Old Oct 10, 2006 | 01:28 PM
itr_18's Avatar
doesnt matter if its B18C or K20/24. If you want make low ET's you have to prepare chassis, suspension, tranny and have a lot of knowledge and make a lot of dynos, track tests etc. Only $$ wont bring you 9's.
Old Oct 11, 2006 | 07:47 AM
lightcrx's Avatar
Default Re: (itr_18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr_18 &raquo;</TD></TR><TR><TD CLASS="quote">doesnt matter if its B18C or K20/24. If you want make low ET's you have to prepare chassis, suspension, tranny and have a lot of knowledge and make a lot of dynos, track tests etc. Only $$ wont bring you 9's.</TD></TR></TABLE>
sure it will you just gotta hire some body that will do all that and a driver :X
Old Oct 11, 2006 | 08:57 AM
Klappi's Avatar
Default Re: (lightcrx)
i have 15K only to put in the engine.
How high it will be (WHP)
Old Oct 11, 2006 | 09:51 AM
rip94delsol's Avatar
Default Re: (Klappi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Klappi &raquo;</TD></TR><TR><TD CLASS="quote">i have 15K only to put in the engine.
How high it will be (WHP)</TD></TR></TABLE>
Wow jeese you dont need that much i dont think! it will be high though.
Old Oct 11, 2006 | 11:35 AM
Klappi's Avatar
Default Re: (rip94delsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rip94delsol &raquo;</TD></TR><TR><TD CLASS="quote">
Wow jeese you dont need that much i dont think! it will be high though.</TD></TR></TABLE>
Do you think it is to much?
Old Oct 11, 2006 | 12:48 PM
If you are paying for the block to get done it may cost that much but if you do the building of the block it comes out to be cheaper! It all depends how far your willing to go.
Old Oct 11, 2006 | 01:56 PM
Klappi's Avatar
I think i will buy a complete new block from benson or golden eagle.
Has anyone links to firm where i can get all the parts i need.?
Old Oct 11, 2006 | 02:05 PM
JDM94EG28's Avatar
with 15k on a bseries def getti you into mid 9's.... even around 12k whould get you there with a bseries with a k-series 15k is about close to the right price you going to be looking at.
Old Oct 11, 2006 | 02:13 PM
Klappi's Avatar
Default Re: (JDM94EG28)
What is all what i need to have many whp.
Please say me your setups what all i must done on the engine.
I would be very good with the price to the parts.
Old Oct 12, 2006 | 03:20 AM
itr_18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Klappi &raquo;</TD></TR><TR><TD CLASS="quote">I think i will buy a complete new block from benson or golden eagle.
Has anyone links to firm where i can get all the parts i need.?</TD></TR></TABLE>
Send PM to earl if you want benson. Choose benson & earl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM94EG28 &raquo;</TD></TR><TR><TD CLASS="quote">with 15k on a bseries def getti you into mid 9's.... even around 12k whould get you there with a bseries with a k-series 15k is about close to the right price you going to be looking at.</TD></TR></TABLE>
not if he want to pay for everything without any know-how etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Klappi &raquo;</TD></TR><TR><TD CLASS="quote">What is all what i need to have many whp.
I would be very good with the price to the parts.</TD></TR></TABLE>
"I need NOS! I need one of these, one of the big ones"
1000's of WHP wont give you good time if you want only POWA!
Old Oct 12, 2006 | 03:53 AM
Klappi's Avatar
Oh no not nos i will only have the whp with 100 octane that is what i haver here to drive
Old Oct 12, 2006 | 04:28 AM
Turbocivic94's Avatar
**** buy a already built car for that price.
Old Oct 12, 2006 | 04:32 AM
Klappi's Avatar
Default Re: (Turbocivic94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 &raquo;</TD></TR><TR><TD CLASS="quote">
**** buy a already built car for that price. </TD></TR></TABLE>
Yes when i would find a perfekt car i will buy it but i dont have found a good one.
