Alarm siren and oem horn...
Old Oct 7, 2006 | 11:43 PM
Lucky 7's Avatar
Default Alarm siren and oem horn...
I want to make my oem horn go off with the alarm siren. I already have relays and a flasher. Anyone have the diagram for it? Thanks
Old Oct 8, 2006 | 08:32 AM
fcm's Avatar
fcm
Old Fart
Default Re: Alarm siren and oem horn... (Lucky 7)
What is the make and model of the alarm?
What is the MM&Y of car it's in? 94
Old Oct 8, 2006 | 09:40 AM
Lucky 7's Avatar
Default Re: Alarm siren and oem horn... (fcm)
viper 600 ESP
96 civic dx
Old Oct 8, 2006 | 10:14 AM
fcm's Avatar
fcm
Old Fart
Skip the flasher, use the light flash output, [pos.(+)] on 85 of relay, connect the alarms orange, [H1/1] neg.(-) armed output to 86 of relay, ground 30 of relay to chassis and connect 87 of relay to horn wire, gray at steering wheel harness or green connector behind radio.
Horn will honk when park lights flash. 94
Old Jun 17, 2008 | 06:28 AM
JasonGhostz's Avatar
Thread revival, similar issue, similar model car... 99 Civic 2DR EX w/KARR alarm that can't be identified.
My Alarm's "Siren" output was previously attached to the Gray Horn wire from the Keyless Unit. It would drop to 0v when the horn would honk, and be +12v at all other times.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Skip the flasher, use the light flash output, [pos.(+)] on 85 of relay, connect the alarms orange, [H1/1] neg.(-) armed output to 86 of relay, ground 30 of relay to chassis and connect 87 of relay to horn wire, gray at steering wheel harness or green connector behind radio.
Horn will honk when park lights flash. 94</TD></TR></TABLE>So, instead of sending 30 to Chassis Ground, am I supposed to use 30 as my "Siren Power Output"?
<FONT COLOR="white">EDIT:</FONT> This will make my siren and horn alternate, right?
<FONT COLOR="white">EDIT:</FONT> Oh shoot.. I think if I do this, and leave my parking lights on, the siren will sound the entire time my alarm is armed.. any way to remedy this?
Thanks again for the help!
JasonGhostz
Modified by JasonGhostz at 7:34 AM 6/17/2008
Old Jun 17, 2008 | 06:39 AM
Default Re: Alarm siren and oem horn... (JasonGhostz)
forget it.. I think I know what I need to do...
30: Alarm's Light Flash Output
85: Alarm's Ground When Armed
86: Alarm's Light Flash Output
87: To Siren(s)
Sound right?
JG
EDIT: this will make the siren sound if the alarm arms with the lights on...
Modified by JasonGhostz at 1:32 PM 6/17/2008
Old Jun 17, 2008 | 02:18 PM
fcm's Avatar
fcm
Old Fart
I would run a fused lead from the batt. to #30, so you have enough output for the horn. 94
Old Jun 17, 2008 | 05:35 PM
I've got a +12v Const that I plan on using for my other sensors. It's already fused at 15A near the tapping source.
Will I still need an additional Fuse from this wire to my Siren Relay #30?
On a similar note, should ALL devices that require power have their own fuse? I haven't hard-wired anything yet, so making the necessary changes isn't a problem...
Thanks again!!
JasonGhostz
Old Jun 19, 2008 | 12:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">I would run a fused lead from the batt. to #30, so you have enough output for the horn. 94</TD></TR></TABLE>Do you mean output for the Lights? This relay isn't going to be connected to my siren/horn wire at all...
Also, what size should the Fuse be, if I'm running up to 2 Mini Piezos ("12V, 110mA" is on the back)? I 'll be connecting #30 to a Const 12v lead that's already got a 15A Fuse. Do I need another Fuse along that wire for this Relay's #30?
Thanks again!
JasonGhostz
Old Jun 19, 2008 | 04:17 PM
fcm's Avatar
fcm
Old Fart
The only time you absolutely need to add a fuse to a line that already has one is if the gauge of wire you add to the existing fused lead is a smaller gauge, you would fuse the smaller gauge wire with the appropriate fuse for that gauge of wire.
Remember, you fuse the lead, not the load, the fuse is there to protect the wire. 94
Old Jun 20, 2008 | 06:22 PM
Got it (^^^). Thanks!
I'll be adding the fuses to the leads to the Sirens. They're really small wires, but I just don't know how small these fuses can go... Time to re-read the sticky to look for answers...
Thanks again!
JasonGhostz
j13
Audio / Security / Video
15
Jan 8, 2013 05:52 PM
nitewolf
Aug 5, 2010 07:03 PM
Shay91Racer
Apr 12, 2007 10:03 AM
accord4door
May 18, 2006 09:43 AM
technine
Dec 17, 2002 08:54 AM
