compatable?
i have no clue about suspension and i did a quick google search but didn't find anything..
will these :
http://i13.photobucket.com/alb...3.jpg
fit my 88 crx? i have a problem with it looking so high up for some reason...
they are skunk 2, 2.5in drop from a 1990-1993 integra. thanks guys
. feel free to tell me why/why not, im always up for learning.
will these :
the spring rates/shock rates will be higher than the one made for your car.
89-91 civics used different rear lower control arms, so you'll have to get arms off one of those cars.
If you have an si, you'll have to make sure you get the arms off an si because of the sway bar mounts.
90-93 integra rear lower control arms will kinda work, the only difference is that the strut mount is moved towards the center of the car a little, so that the rear spring/shock rates will be slightly lower in the real world. I wouldn't suggest them (but at the same time, I have them on my car)
EDIT-------> I just looked at the pic. They're just lowering springs with stock shocks. I wouldn't get them. I saw skunk and immediately thought coilovers. My fault.
