Short Shifter swap write-up
Old Oct 7, 2006 | 03:51 PM
mojo_stevo's Avatar
Default Short Shifter swap write-up
I know most of you know how to do this, but I'll post it for those who don't, and yes I know there is a write up elsewhere... but it's not on H-T... so now one is.
It took me and a friend about 40 minutes to do this.
So first un-attach the **** from the boot by pulling the plastic part down ( May need assistance from flat head)
The unscrew the ****.
Next pull off the middle section of the center console. There are 3 screws on the side, and two below the climate control. Then take off the 4 main bolts with the bushings under them.
On top take out the bolt that holds the linkage in place.
okay this next photo I stole from another write up because I forgot to take it. Thank you--->http://absoluteprelude.com/for...ID=40
Remove the bolt that Ludinitup is pointing to.
Then drop the shifter out through the bottom of the assembly, and remove the two bolts holding in the bearing assembly, and the plastic cube off of the side pivot.
Swap them over to the short shifter.
Reinstall it through the bottom and lock the plastic cube in to place.
Bolt everything back in place.
Prior to replacing the console, your need to remove the plastic from the front of the shift boot retainer because the the linkage will knock into it at 1st, 3rd, and 5th. I chose to use a rotary tool with a drill bit to cut, and a sander to finish... wear glasses because it will throw molten globs of plastic everywhere.
Put it all back together and shift away.
Thank you Ludinitup at Absolute Prelude for the tips.
Old Oct 7, 2006 | 04:03 PM
.BigSexy's Avatar
most hood white kid
Default Re: Short Shifter swap write-up (mojo_stevo)
nice write up steveo...hows it feel?
Old Oct 7, 2006 | 04:04 PM
dwnsthGABOY's Avatar
is this the forbidden short shifter?
Go figure I was about to make a thread aking about a short shifter.
Which is better the forbidden one or the one offered by B&M?
i've heard of the B&M one breaking is that possible?
Old Oct 7, 2006 | 04:13 PM
mojo_stevo's Avatar
Default Re: (dwnsthGABOY)
Forbidden hands down is the bomb. I love it. It cuts the throw by almost half, and feel solid at F***. No more loose as a goose shifter, and there is no time for your car to buck when you casually shift. Kiss that long *** 4th->5th throw goodbye. When you give it hell it just flies to the next gear. Just make sure you set it to the top hole, it's the shortest throw. Shifts like a Miata.
Old Oct 7, 2006 | 04:17 PM
Default Re: (mojo_stevo)
thanks, Good write up.
Old Oct 7, 2006 | 04:19 PM
0h teh sl0w k20!!'s Avatar
so it is the forbidden short shifter?? cant wait for it to be available for a 5th gen.. this is on my top list to buy
Old Oct 7, 2006 | 07:34 PM
mojo_stevo's Avatar
I'm pleased with it. I drove my friends EG with the OBX, and it was too light and cheep fealing.
Old Oct 8, 2006 | 07:20 AM
lak8's Avatar
i own a 4bidden shoft shifter also and its great
Old Oct 8, 2006 | 07:54 AM
H22a T13's Avatar
I broke my cube somehow gotta go to honda tomorrow, but this shifter fing owns good write up!
Old Oct 8, 2006 | 08:25 AM
mojo_stevo's Avatar
Default Re: Short Shifter swap write-up (H22a T13)
I was so worried about breaking mine, I used channel locks to get it off so that the teeth wouldn't crack it. Just grease the hell out of it when you put the new one on.
integratypeRs
Jun 6, 2009 10:00 PM
lilvietboy
Mar 1, 2009 05:33 PM
nicko360
Feb 8, 2007 01:31 PM
elevatethis
27
Aug 10, 2004 11:12 PM
Wattup Though 00
Mar 25, 2004 04:23 AM
