throttle cable
Old Oct 7, 2006 | 02:15 PM
C1CRX's Avatar
Traffic signal tech
Default throttle cable
hey guys i just got back from the acura dealer after buying a throttle cable which i thought was for a 94+GSR and after checking the part number online its for a 90-93 integra i was going to use this on a B18c1 swap into my crx with a stock 94+GSR intake mani. and was wondering would i have to go back to the dealership and get a throttle cable for a 94+ GSR or would this work please let me know asap as the dealership closes in about an hour.
Old Oct 7, 2006 | 04:49 PM
DC_RaceR's Avatar
Default Re: throttle cable (C1CRX)
If you used the GSR TB.. Then you'll need the GSR cable.
Old Oct 7, 2006 | 04:52 PM
C1CRX's Avatar
Traffic signal tech
ok thanks expletive now i need to go back to the dealership which is far as hell from my house!
Old Oct 7, 2006 | 04:55 PM
philkehn's Avatar
Im using a 90-93 on my b16 with a little modding to the bracket, the 94 one may be a little different if the hole is in a different spot on the firewall from an integra to a crx...
Old Oct 7, 2006 | 08:57 PM
crxnj's Avatar
ive done many of these swaps,and always use the stock crx/civic si throttle cable,,,,the 90-93 teg is to long with that setup
Old Oct 8, 2006 | 08:55 AM
philkehn's Avatar
Default Re: throttle cable (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">ive done many of these swaps,and always use the stock crx/civic si throttle cable,,,,the 90-93 teg is to long with that setup</TD></TR></TABLE>
I did my swap in a dx so i had to swap my throttle cable Youve probably done more swaps then me so i would listen to you
Old Oct 8, 2006 | 01:49 PM
crxnj's Avatar
Default Re: throttle cable (philkehn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philkehn &raquo;</TD></TR><TR><TD CLASS="quote">
I did my swap in a dx so i had to swap my throttle cable Youve probably done more swaps then me so i would listen to you </TD></TR></TABLE>
The thing is though,,the gsr b18c intake setup is alot different then the b16 or other b-series swaps....using the 90-93 teg throttle cable on other b-series motors is fine,but with the gsr b18c its to long..
Old Oct 8, 2006 | 04:52 PM
C1CRX's Avatar
Traffic signal tech
thanks for all the suggestions guys ill elt you know which one i end up using
Old Oct 8, 2006 | 05:09 PM
DC_RaceR's Avatar
Default Re: (C1CRX)
I did mine...
CRx with LS swap.. GSR TB... I tried stock and DA cables... will not hold good on the bracket. GSR works like a charm.
I have 2 DA and HF laying around... spending money where it's not need.
crx90421
Oct 8, 2009 11:45 PM
Ryan562
11
Jan 14, 2007 11:56 PM
90jdmcrxdude
May 19, 2006 02:27 PM
99teggsr
Mar 13, 2005 10:19 AM
V8 BAIT
Dec 1, 2002 10:54 AM
